liljekvist
www.mxwheel.se
Nej det går alldeles utmärkt men det blir lite tråkig effekt av det bara![]()
nu hitta jag info om det jag svammlade om innan. Stog klart och tydligt i info mailet som gick ut från aprilia till alla ÅF
The fundamental innovation of the MXV 450 lies in the availability of two performance levels, made possible by two timing settings and designed to satisfy all possible power delivery needs. The factory default setting is “Big Bang”. The second “Screamer” setting offers more regular firing.
The strong point of the “Big Bang” setting is the exceptional ridability it confers on the bike. With Big Bang active, the firing gap between the two cylinders is closed up to produce the excellent performance so typical of a twin while also guaranteeing easier control and better traction, two features that riders are bound to appreciate over slippery surfaces.
The “Screamer” setting requires a minor modification to the engine and a new mapping. With Screamer active, the firing gap is the standard gap for a 77° V twin. “Screamer” delivers the maximum engine performance suitable for expert riders.
så frågan är vad minor är... ser ut som en skum sak sitter på den bakre cylindern vid kamen på mxv bilderna innan.
