Reinstall the large, thin washer onto the backside of the needle bearing housing and slide the bearing and washer onto the crankshaft - Be careful the washer doesn't fall off the needle bearing and get crushed. Suggest using a dab of grease to hold it on.
Install the starter clutch into the flywheel and line up the flywheel marks to the single timing notch mark.
Install plate washer and reinstall the red or blue loctited crankshaft nut to Ducati torque specs.
152 ftlbs / 207n-m torque
Clean case and cover gasket surfaces with degreaser and lightly dab Three Bond non-hardening grey sealant OR your favorite Ducati concoction. I just don't want to see orange high temp silicone sealant on your Ducati.
Replace cover screws and the crank cover, the clutch slave cylinder and external shift linkage.
ADD OIL!!!!
Foto: Karin Tornblom Pre... |
