EbolaSmurf
n00b
Saxat från KTMforum.co.uk av Richard_C
This help?
Select the correct connector (there are three)
Un-couple the connector to expose the three pins. You can see the plastic tongues beneath the metal pins.
Using a jewellers screwdriver or similar, press down to disengage the plastic toungue. At the same time, holding the relevant wire, pull out the pins from the other end of the connector.
Remove the grey and yellow/brown cables.
You can use heatshrink or insulating tape to cover the two pins. (The third pin has been removed to allow the heatshrink to be fitted in the next stage.
Larger heatshrink sleeve used to secure the loose cables. You could use insulating tape instead.
The connector reassembled with some rubber grommets used to plug the open holes (this is not essential).
Hoppas det kommer till användning.. ska göra detta efter 750mils servicen tänkte jag när Leo kannorna åker på..
Känns som ett enkelt ingrepp som är enkelt att återställa..
Har för mig att om man tar bort alla tre så kommer en varningslampa lysa på instrumentpanelen...
			This help?
