WSBK / SS600 - Silly season 2009
Motosprints uppdaterade (inofficiella) lista:
1. Rea (Honda) 1’42”156
2. Fabrizio (Ducati) 1’42”362
3. Cruthlow (Yamaha) 1’42”795
4. Haga (Ducati) 1’43”054
5. Biaggi (Aprilia) 1’43”444
6. Haslam (Suzuki) 1’43”512
7. Toseland (Yamaha) 1’43”699
8. Neukirchner (Honda) 1’43”809
9. Guintoli (Suzuki) 1’43”810
10. Checa (Ducati) 1’43”894
11. Lascorz (Kawasaki) 1’43”950
12. Camier (Aprilia) 1’44”013
13. Berger (Honda) 1’45”213
14. Sykes (Kawasaki) 1’45”855
15. Laconi (Ducati) 1’46”470
16. Hofmann (Aprilia) 1’46”759
17. Praia (Ducati) 1’47”084
18. Takahashi (Kawasaki) 1’49”272
Checa på Althea Ducati:
Toseland:
Toseland körde med samma inställningar som Spies, förutom växelspaken eftersom Ben har en skostorlek större. Toseland har inte kört på den här banan tidigare..
Var det inte Cruthlow som vart förbannad för att han vart utan wsbk styrningen 2009 dvs den som Sykes fick.
Nya regler i WSBK till nästa år. Förändringarna i reglementet är med fet text.
2.9.2.2 Subsequent Homologations for Superbike and Homologation for Supersport and Superstock.
A manufacturer which has previously homologated a motorcycle in Superbike and is requesting a new homologation, or a manufacturer requesting a homologation for Supersport or Superstock must follow the procedure below:
- The manufacturer must have produced at least a quantity of 250 motorcycles prior to the homologation inspection. The motorcycle must be on sale to the public at that time.
- The minimum quantity of 1000 units must be reached by the end of June of the current year.
- The minimum quantity of 2000 units must be reached 15 days before the last race of the Championship or Cup of the current year.
- All motorcycles must be identical to the model to be homologated with the same specifications.
- Proof of production quantities must be provided by certified documentation as stated in Article 2.9.2.
- The FIM will withdraw the homologation if these rules are not respected.
2.4.7 Tyres
To add:
Only two rim sizes (3.50 x 16.5 and 3.75 x 16.5) shall be allowed for the front tyre and only one rim sizes (6.25 x 16.5) shall be allowed for the rear tyre.
2.4.8.1.2 Carburation Instruments for 1000cc 3 & 4 cylinders and 1200cc 2 cylinders
Carburation instruments refer to throttle bodies and variable length intake tract devices.
• The original homologated carburation instruments must be used unmodified.
• The use of optional homologated carburation instruments is not allowed.
• The fuel injectors may be replaced, however they must fit without modification to the homologated throttle body.
• The carburation instruments intake insulators may be modified.
• Bell mouths (including their fixing points) may be altered or replaced.
• Vacuum slides may be fixed in the open position
• Secondary throttle valves and shafts may be removed or fixed in the open position and the electronics may be disconnected or removed.
Only for motorcycles homologated after the 1st of January 2010.
• Electronically controlled throttle valves, known as ‘ride-by-wire’ systems, may be used exclusively if the homologated model is equipped with this system. Software may be modified but all safety systems and procedures designed by the original manufacturer must be maintained.
2.4.8.12 Transmission / Gearbox
All transmission/gearbox ratios, shafts, drums, selector forks are free.
Primary gear ratios are free.
The number of gears must remain as homologated.
Additions to gearbox or selector mechanism, such as quick shift systems, are allowed.
Countershaft sprocket, rear wheel sprocket, chain pitch and size may be changed.
Any power source (i.e. hydraulic or electric) cannot be used for gear selection, if not installed in the homologated model for road use. Human power and so called quick shift systems are excluded from the ban.
2.4.8.13 Clutch
Aftermarket or modified clutches are permitted.
Back torque limiter is permitted.
Any power source (i.e. hydraulic or electric) cannot be used for clutch operation, if not installed in the homologated model for road use. Human power is excluded from the ban.
• For 1000 cc 2 cylinders
Clutch system (wet or dry type) and method of operation (cable/hydraulic) may be altered or replaced from those fitted to the homologated motorcycle.
• For 1000 cc 3 & 4 cylinders and 1200cc 2 cylinders
Clutch system (wet or dry type) and method of operation (cable/hydraulic) must remain as homologated.
2.4.8.16 Air Box
The air box may be altered or replaced from those fitted to the homologated motorcycle (a special design for racing is allowed). If fuel injectors are attached to the cover of the air box, their position with reference to the throttle body must remain as original.
The air filter element may be removed.
The air box must be completely closed around the induction bell mouth and all engine breather tubes. Carburation instruments may be entirely within the air box.
The air box drains must be sealed.
All motorcycles must have a closed breather system. All the oil breather lines must be connected and discharge in the air box.
The breather system (air box plus any breather oil collector box) must be capable in the event of drain pipe blockage, of retaining a minimum of 1000 cc of discharged fluid.
The air box must remain as originally produced by the manufacturer on the homologated motorcycle.
Air filters, internal flap type valve, sensors and vacuum fittings may be removed, modified, or replaced with aftermarket parts.
Any holes in the air box to the outside atmosphere resulting from the removal of components must be completely sealed from incoming air.
Ram air tubes or ducts running from the fairing to the air box may be modified, replaced or removed. If tubes/ducts are utilized, they must be attached to the original, unmodified air box inlets.
2.4.10.2 Front Forks
The front fork in whole or part may be changed but must be the same type homologated (leading link, telescopic, etc.).
No aftermarket or prototype electronically-controlled suspensions may be used. If original electronic suspensions are used, they must be completely standard (any mechanical or electronic part must remain as homologated).
The original electronic system must work properly in the event of an electric/electronic failure otherwise it cannot be homologated for FIM competitions.
The upper and lower fork clamps (triple clamp, fork bridges) may be changed or
modified.
Steering damper may be added or replaced with an after market damper.
The steering damper cannot act as a steering lock limiting device.
Electronic controlled steering damper cannot be used if not installed in the homologated model for road use. However, it must be completely standard (any mechanical or electronic part must remain as homologated).
2.4.10.6 Brakes
Front master cylinder may be altered or replaced from those fitted to the homologated motorcycle.
Rear master cylinder may be altered or replaced from those fitted to the homologated motorcycle.
Front calipers may be altered or replaced from those fitted to the homologated motorcycle.
Rear calipers may be altered or replaced from those fitted to the homologated motorcycle.
Brake pads or shoes may be altered or replaced from those fitted to the homologated motorcycle.
Brake hoses and brake couplings may be altered or replaced from those fitted to the homologated motorcycle. The split of the front brake lines for both front brake calipers must be made above the lower fork bridge (lower triple clamp).
Brake discs may be altered or replaced from those fitted to the homologated motorcycle. Only ferrous materials are allowed for brake discs. The use of exotic alloy materials for discs and brake calipers (i.e. aluminium beryllium, etc.) is not allowed.
ABS (Antilock Brake System) may be used only if installed in the homologated model for road use. However, it must be completely standard (any mechanical or electronic part must remain as homologated, brake discs and master caliper levers excluded), and only the software of the ABS may be modified.
Application 2011
• Injectors must be stock and unaltered from the original specification and manufacture.
• Vacuum slides may be fixed in the open position.
2.4.8.17 Fuel supply
The engine control unit (ECU) may be modified or changed.
Fuel pump and fuel pressure regulator must remain same as on the homologated model. (Max pressure will be defined in the homologation papers and the fuel line must be modified to allow standardized checks by technical stewards).
No mechanical fuel pump is allowed unless installed in the homologated model.
Fuel lines from fuel tank up to the injectors (fuel hoses, delivery pipe assembly, joints, clamps, fuel canister) may be replaced.
The fuel line(s) going from the fuel tank to the carburation instruments must be located in such a way that they are protected from possible crash damage.
Fuel vent lines may be replaced.
Fuel filters may be added.
Fuel petcock may be altered or replaced from those fitted to the homologated motorcycle.
Aprilia med ny huvudsponsor nästa år. Italienska flygbolaget Alitalia.
Haslam nöjd anställd hos Suzuki ..
“This is the first time I’ve ridden for a full factory team. You always think the grass is going to be greener and it is. I can’t pick fault with anything they’ve done. Everything is organised so all I have to do is ride the bike which is prefect for me.”
Haslam completed 280 laps over the three day Phillip Island test despite having to cope with blistering temperatures which resulted in 65 degree track temperatures.
He said:
“When we were there it was a heat wave and that meant we could only really set fast times early in the morning or late in the afternoon. I’m not allowed to speak about lap times, but what I can say is that I’m really happy.”
Haslam spent the three days lapping with new team-mate Sylvan Guintoli who was also in impressive form despite hitting a number of seagulls during the test.
Haslam said:
“There was only two of us lapping so it took time to clean the track. Between myself and Sylvan I think we hit about eight birds. Sylvan hit one with his helmet on the start finish straight which was a bit messy.”
The two men used the test to evaluate new parts including a back to back test between Ohlins and Showa suspension, with the Belgium run squad expected to make the full time switch to Ohlins in 2010.
Superstock 600 har blivit flyttade till att köra sina race på lördagar på WSBK-helgerna nästa år. Istället kör man en Triump 675 Cup på söndagarna. Den cupen kommer vara med på 7st helger och anmälningsavgiften är 27.000 euro om man betalar innan 22 januari eller 30.000 euro efter det datumet. Startavgiften är exlusive moms.
Yoshimura Japan kanske har ett team i WSBK nästa år, vore jäkligt kul
Tydligen är detta en protest mot vad som sker i Japan där man varit hårda mot dom som överskridit decibel-gränsen. Yoshimura Suzuki hade stora problem med det under 2009. Även andra team hade problem med detta. Bl.a gick segern i JSBK till Katsuyuki Nakasuga/Yamaha YSP Racing Team då Chojun Kameya/Sakurai Team blev diskade på finalen på Motegi för att dom inte klarade decibel-gränsen efter racet.
1 januari lade det Japanska förbundet ut årets regler/klasss som ska gälla för 2010. Men det som återstår är dock att komma fram till vilken decibel-gräns som ska gälla i JSBK. Flera team och ljuddämpartillverkare säger att det är "omöjligt för dem att stanna kvar i JSBK" om man sänker gränsen. Därför kommer ledningen för dom som skriver reglementet ha möte med teamen innom några veckor.
Gränsen dom hade i JSBK 2009 var 118db/A.
aha, hoppas det inte bara va ett skrämskott för att påverka detta, vore så fränt att ha med dom i vm.
Aprilia skriver historia
Nytt i MotoGP till 2027
Fyra nya Triumph-modeller
