jo stämmer 04-05 är samma. 06-07 är kortare, starkare och snabbare
New for 2006
- New cylinder-head porting for improved engine power in mid- and upper-rpm ranges.
- New cylinder-head combustion chamber shape raises the compression ratio.
- New intake cam increases power at high engine speeds.
- New intake valves help increase power.
- Intake valve springs change from a single spring to new double-spring design for optimum performance at high rpm.
- Redline increased for improved performance.
- Left engine ACG cover is made of magnesium for lighter weight.
- New transmission gears for improved engagement.
- New clutch needle bearings improve engagement feel and durability.
- Redesigned ram-air intake screen grid reduces air resistance for optimum flow.
- New exhaust system is lighter and increases flow for more power.
- New chassis geometry for improved handling.
- New, larger full-floating 320mm front disc brakes (up from 310mm) with four-piston radial-mounted calipers deliver superior braking performance and progressive feel.
- Revised front suspension settings for superior suspension action.
- Revised rear suspension includes new linkage for improved handling.
- All-new bodywork includes upper, middle and lower cowl for aggressive, race-ready look.
- Improved seat foam for additional rider comfort.
- Exciting new colors are: Candy Blue/Yellow, Red/Black, Silver/Metallic Silver and Black.
Jag har en 06:a som gått ca 3800 mil som e till salu.
