Tjenare!
Ska sälja iväg en gamal racehoj jag har och tänkte göra en vintilkoll innan jag skickar iväg den. Någon som har koll på ventilspelet på denna modell??
2002 GSXR 1000 SPECIFICATIONS
DIMENSIONS AND DRY MASS
Overall length............................................................ 2045 mm (80.5 in)
Overall width............................................................. 715 mm (28.1 in)
Overall height............................................................ 1135 mm (44.7 in)
Wheelbase.................................................................. 1410 mm (55.5 in)
Ground clearance....................................................... 130 mm (5.1 in)
Seat height................................................................. 830 mm (32.7 in)
Dry mass.................................................................... 171 kg (376 lbs)
ENGINE
Type........................................................................... Four-stroke, Liquid-cooled, DOHC
Number of cylinders.................................................. 4
Valve clearance Insug.................................................... 0.10 – 0.20 mm (0.004 – 0.008 in)
Ventilspel avgas.................................................... 0.20 – 0.30 mm (0.008 – 0.012 in)
