Updated Yamaha R1 superbike featuring clever aero package
kaninfaan
20 Apr 2024
Kraftfahrzeug Trunkenpolz Mattighofen und/そして 2019 Yamaha R6
Updated Yamaha R1 superbike featuring clever aero package teased in new patent images​
Skall ny aero rädda euro5+/euro6 certifiering? :yoparty
och för att MCN's pay-or-spread-your-cheeks-wall verkar bromsa så paste'ar jag in hela artikeln här
  • 2025 Yamaha R1 cornering on track
1 of 6
At the moment Yamaha’s R1 is a track-only superbike in European markets after the company opted not to uprate the design to meet the latest Euro5+ emissions requirements.
But that doesn’t mean development has come to a halt, and a new patent application reveals how active bodywork could be a key to not only improving performance but also meeting those pesky emissions limits.
The idea of movable shutters controlling the airflow through a cooling system isn’t new. It was relatively commonplace on prewar cars, with both manual and automated radiator shutter systems in use long before thermostats took over as a cheaper and simpler way of achieving the same goal of maintaining optimum engine temperatures.
Details revealed on Yamaha R1 patent image
In more recent years, cars have again returned to the idea with many modern models having hidden, automated shutters in their cooling openings, closing them off when not needed in pursuit of improved aerodynamics and better fuel economy.
Yamaha’s latest patent – showing new bodywork designed for the current-generation R1 – takes a slightly different route by installing the movable shutters on the cooling outlets in the fairing sides rather than the radiator intake at the front.
These are operated by small, fairing-mounted stepper motors – which move in defined steps and monitor their angular position – and a simple system of belts, keeping weight and cost down. Sensors monitor coolant temperature, catalyst temperature, outside air temperature, speed and throttle position, allowing a control unit to decide how much to open the vents.
Patent image overlaid on a Yamaha R1
The idea is that when the shutters are closed, airflow inside the fairing will be reduced, lowering the bike’s cooling capacity and creating a bubble of high-pressure air in front of the radiator intake that encourages more airflow around the sides of the bike.
The airflow running past the vents on the fairing, which is normally disrupted by the slow-moving, turbulent air that comes out of them, is also cleaned up, reducing the bike’s overall drag so it can reach higher speeds using less power, and the side fairing panels are more enclosing than the current design – covering the whole engine and giving a smoother path for the outside airflow.
Since bikes are designed with worst-case cooling scenarios in mind, like being stuck in traffic on hot days, the vents would be able to remain closed much of the time in cooler temperatures and at higher speeds, so the aero benefits could be substantial.
Tucked in on the track-only Yamaha R1
The patent also mentions the challenge of getting catalytic converters up to operating temperature fast and keeping them in the optimum range, explaining how the variable vents could assist in that task; an important one, particularly in light of the current-generation R1’s failure to meet Euro5+ rules.
It also describes how, by monitoring speed and throttle position, the system could be programmed to briefly sacrifice cooling in pursuit of better performance, keeping the vents closed under full throttle acceleration or near top speed, for example.
In World Superbike racing, where movable aerodynamics are allowed if they’re fitted as standard to the homologated street bike the racer is based on, that could be a key advantage.
Superbikes making a comeback​
Pulling a wheelie aboard the Suzuki GSX-R1000R
Suzuki’s recent revival of the GSX-R1000R as a Euro5+ European model, three years after its predecessor was dropped from the range in the face of Euro5 in 2022, shows that bikes can make a comeback after an emissions-enforced market withdrawal.
The fact that Yamaha engineers are working on ideas to update the R1, adding performance and improving emissions, is a positive sign that it, too, could be plotting a mainstream return.
:yamaha-r1-aero-update-1.jpgyamaha-r1-aero-update-2.jpgyamaha-r1-aero-update-3.jpgyamaha-r1-aero-update-4.jpgyamaha-r1-aero-update-5.jpgyamaha-r1-aero-update-6.jpg
That’s actually pretty exciting! Active aero on the R1 could make a huge difference both on track and for emissions compliance. If Yamaha pulls this off and brings it back to the streets under Euro5+, it’s going to be one hell of a comeback.
Vore det inte bättre att bara sälja en hoj med typ Hayabusakåpkit för att dra ner luftmotståndet till ett minimum, och sedan sälja ett "racekit" kåpor vid sidan av som gör att hojen går att se på också?
Fast då måste ju båda ändå vara en del av helfordonsgodkännandet, med samma utsläppskrav osv. Om det inte ska vara race only då, och då tappar man ju ändå gatmarknaden.
Usch... Tänkte inte på helfordonsgodkännandet... Detta satans påfund.
Så länge en helförsäkring ligger runt 50k så lär det inte säljas så många R1 i Sverige oavsett nya finesser eller ej. Kanske billigare försäkring i USA apropå att man fortfarande kan köpa ny R1 för gata där.
App app app! Helfordonsgodkännandet är visserligen knöligt men utan det hade vi behövt speciella modeller till sverige med strypsatser och grejer och det hojarna hade varit betydligt dyrare eftersom de hade varit specialanpassade för en liten skitmarknad. På grund av det hade vi även haft ett betydligt mindre utbud av modeller.
Helfordonsgodkännandet är ett av få saker som faktiskt varit positivt med EU... :)
Vi slapp även kravet på baklysen under dagtid vilket är ett piss i vårt halvskumraskiga höst/vinter/vår-land. Man kan bli pryglad på torget för att man bytt CD-skiva i bilens CD-spelare när man tröttnat på det obligatoriska U2-albumet som alla människor ska höra alla dagar året om, och riskerar att få sina barn placerade på fosterhem om man sätter på ett öppet luftfilter...
I´ts a hard life... :)
Påvens BMW R18 utauktionerad
GGN 2025, värsta hittills !
Bildsvep – GGN 2025
MysEnduro i Laxå I sönda...
Bike nr 10 lämnad till tryck!
Missa inte Katalogen 2026!
  Stora Motorcykel...
David Knight, Ducati Åre...
Ny Brutale från MV Agusta
