Vänta du tills ungarna sitter bredvid i soffan och slötittar och dricker upp din öl.....
Bränner den bron när jag kommer till den.
movemequotes.com
Du kanske kan svara på något jag undrat.Denna passar in på SD's talkvinna (för de lågbegåvade, hon är åsnan i berättelsen)
When Arguing Is Futile—Short Story Of The Donkey And The Tiger
In this short story, a heated debate arises between a donkey and a tiger so they go to the lion for help. What he advises might surprise you.movemequotes.com
The donkey told the tiger, “The grass is blue.”
The tiger replied, “No, the grass is green.”
The discussion became heated, and the two decided to submit the issue to arbitration, so they approached the lion.
As they approached the lion on his throne, the donkey started screaming: ′′Your Highness, isn’t it true that the grass is blue?”
The lion replied: “If you believe it is true, the grass is blue.”
The donkey rushed forward and continued: ′′The tiger disagrees with me, contradicts me and annoys me. Please punish him.”
The king then declared: ′′The tiger will be punished with 3 days of silence.”
The donkey jumped with joy and went on his way, content and repeating ′′The grass is blue, the grass is blue…”
The tiger asked the lion, “Your Majesty, why have you punished me, after all, the grass is green?”
The lion replied, ′′You’ve known and seen the grass is green.”
The tiger asked, ′′So why do you punish me?”
The lion replied, “That has nothing to do with the question of whether the grass is blue or green. The punishment is because it is degrading for a brave, intelligent creature like you to waste time arguing with an ass, and on top of that, you came and bothered me with that question just to validate something you already knew was true!”
The biggest waste of time is arguing with the fool and fanatic who doesn’t care about truth or reality, but only the victory of his beliefs and illusions.
Never waste time on discussions that make no sense. There are people who, for all the evidence presented to them, do not have the ability to understand.
Others who are blinded by ego, hatred and resentment, and the only thing that they want is to be right even if they aren’t.
Förmodligen, själv så blir jag spyfärdig på vissa röda och gröna nyanser....Du kanske kan svara på något jag undrat.
Upplever vi färger likadant eller är det på en glidande skala?
Båda kan ha rätt mao, enligt sin egen upplevelse?Förmodligen, själv så blir jag spyfärdig på vissa röda och gröna nyanser....![]()
Precis, definitionsfråga uppstår. Det som blir konstigt i exemplet är att de är oense om namningen. Oavsett hur de upplever den specifika färgen borde deras version ändå fått samma benämning.Vad tycker du att det ska vara för färg?
Ett intressant exempel på att hur vi uppfattar färger är väldigt beroende på vad hjärnan har fått för sig är orange. Egentligen är det en ljusbrun våglängd av ljus som hjärnan använder diverse knep för att skilja från de andra bruna våglängderna.Precis, definitionsfråga uppstår. Det som blir konstigt i exemplet är att de är oense om namningen. Oavsett hur de upplever den specifika färgen borde deras version ändå fått samma benämning.
Det finns https://ncscolour.com/sv/ncs/ för att kunna bestämma kulörerBåda kan ha rätt mao, enligt sin egen upplevelse?
Det tjänns väl bra!Jag syftade mer på att i dagens samhälle är det viktigaste inte fakta utan hur man tycker det ska vara.
Jag har sett den där men med en nakenmodell och texten "6 hours later"
Jag såg självscanning 1:a gången 2001 i USA.Historien upprepas gång på gång.
Läste idag att butiker på västkusten tar bort självutscanning på grund av för mycket stölder.
Det är så typiskt, vi får förtroende av butiksägarna och genast så ska det fuskas med att inte scanna allt som man har i korgen.
Detta kände jag på mig då det dök upp och har bara väntat på att denna dag skulle komma.
Ruttet beteende oavsett vad man får av någon, synd att folk inte kan lära sig att visa respekt gentemot den som ger eller vill underlätta livet i olika sammanhang.
Nya BMW S 1000 RR tar form
Sommarauktion hos Antiqueweb
HJC stärker kundrelationen
Sportsterbygge i nästa nummer
