Hej
visst finns det du frågar efter
Something different: thermal insulating paint with high efficiency
While looking for ways to improve the thermal efficiency of racing engines I came across this very special ceramic insulation paint.
This product was invented to insulate spacecraft. This stuff is why most spacecraft are white.
A more down to earth version was developed in Russia for tackling insulation problems in houses and industry.
Cold Russian winters make good insulation a matter of vital importance.
I got hold of a sample to test for my tests on engine parts.
The insulating capacity of this stuff is simly amazing !
The factory claims 1mm of paint equals 50mm of glasswool.
I did tests with a aluminium plate half covered with the coating on the coocking plate.
While the uncoated side is hot enough to bake an egg ,you can touch the coated side by hand !
Coating is simple ,the acryl based product can be brushed on like paint.
Typical use: walls ,roofs ,pipelines ,steampipes ,heating systems ,trucktrailer roofs ,boats ,airco systems ,etc.
The paint is watersolvable ,UV-water and frostresistant and it can withstand permanent temperatures up to 180 degree celcius.
The new branch "EMOT isolatietechniek" will market this product.
And in engines ??
Well ,the paint is not gasoline resistant ,so I had to invent a way to seal it off.
Which I found ,and the first engines with coated internals are doing tests.
The paint has a peaktemperature resistance of 250 degree ,which is not enough for exhausts.
But the factory is developing a high temperature version.
Prata med MARTIN på Emot i nederländerna
http://www.emot.nl/index.php
tror han är general agent för detta i europa.
mvh moddler
