RSV4 -Tråden
Pär
Det var inte jag
22 Sep 2003
Svenska Rivieran
Aprilia RSV4 Factory, Aprilia RS250 ,RD350-84
2010 Aprilia RSV4 Factory - Intermational Specifications
MSRP: £NA
Engine: Aprilia longitudinal 65° V-4 cylinder, 4-stroke, liquid cooling system, double overhead camshafts (DOHC), four valves per cylinder
Fuel: Unleaded gasoline
Bore x Stroke: 78 x 52.3 mm
Total displacement: 999.6 cc
Compression ratio: 13:1
Maximum power at the crank: 180 CV (132,4 kW) a 12.500 rpm
Maximum torque at the crank: 115 Nm a 10.000 rpm
Fuel system: Airbox with front dynamic air intakes. Variable length intake ducts controlled via ECU. 4 Weber-Marelli 48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion Track Sport Road
Ignition: Magneti Marelli digital electronic ignition system integrated in engine control system, with one spark plug per cylinder and “stick-coil”-type coils
Starting: Electric
Exhaust: system 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter (Euro 3)
Generator: Flywheel mounted 420W alternator with rare earth magnets
Lubrification: Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Gear box: 6-speed cassette type gearbox 1st: 39/15 (2.6) 2nd: 33/16 (2,063) 3rd: 34/20 (1.7) 4th: 32/22 (1,455) 5th: 34/26 (1,308) 6th: 33/27 (1,222)
Clutch: Multi-disc oil-bath, with mechanical slipper system
Primary drive: Straight cut gears and integrated flexible coupling, drive ratio: 73/44 (1,659)
Final drive: Chain: Drive ratio: 40/16 (2,5)
Frame: Twin-spar adjustable aluminium frame, with castings and pressings. Envisaged adjustments: - headstock position and rake - engine height - swingarm pin height Öhlins adjustable steering dumper
Front suspension: Öhlins Racing upside-down fork, 43-mm stanchions (with Tin surface treatment). Low profile forged aluminium radial caliper mountings. Completely adjustable spring preload and hydraulic compression and rebound damping. Wheel travel: 120 mm
Rear suspension: Twin sided aluminium swingarm; mixed low thickness and sheet casting technology. Öhlins Racing monoshock with piggyback with completely adjustable: spring preload, wheelbase and hydraulic compression and rebound damping. APS progressive linkages. Wheel travel: 130 mm
Brakes: Front: Dual 320-mm diameter floating stainless steel disc with lightweight stainless steel rotor and aluminium flange with 6 pins. Brembo monobloc radial callipers with 4 34-mm opposite. Sintered pads. Radial pump and metal braided brake hose. Rear: 220-mm diameter disc; Brembo floating caliper with two 32-mm isolated pistons. Sintered pads. Pump with integrated tank and metal braided hose.
Wheels: Aprilia forged aluminium alloy rims, completely machined, 5 split spokes. Front:3.5”X17” Rear: 6”X17”
Tyres: Radial tubeless. Front: 120/70 ZR 17 Rear: 190/55 ZR 17 (alternative: 190/50 ZR 17)
Dimensions: (default settings) Max. length: 2040 mm Max. width: 735 mm (at the handlebar) Max. height: 1120 mm Min. height from the ground: 130 mm Saddle height: 845 mm Centre to centre distance: 1420 mm Trail: 105 mm Steering angle: 24.5°
Dry weight: 179 kg *
Fuel tank capacity: 17 litres (4-litre reserve included)
Other: *Dry weight, without battery and fluids.
2010 Aprilia RSV4R - Intermational Specifications
MSRP: £NA
Fuel: Unleaded fuel
Fuel system: Airbox with front dynamic air intakes. 4 Weber-Marelli 48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion: T (Track), S (Sport), R (Road)
Starting: Electric
Exhaust: 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter (Euro 3)
Clutch: Multiplate wet clutch with mechanical slipper system
Final drive: Chain: Drive ratio: 40/16 (2.5) or 42/16 (2.625)
Frame: Aluminium dual beam chassis with pressed and cast sheet elements. Sachs steering damper
Front suspension: Upside-down Showa fork with Ø 43 mm stanchions. Forged aluminium radial calliper mounting brackets. Completely adjustable spring preload and hydraulic compression and rebound damping. Wheel travel: 120 mm
Rear suspension: Twin sided aluminium swingarm; mixed low thickness and sheet casting technology. Sachs piggy back monoshock with completely adjustable: spring preload, wheelbase, hydraulic compression and rebound damping. APS progressive linkage. Wheel travel 130mm
Brakes: Front: Dual 320-mm diameter floating stainless steel disc with lightweight stainless steel rotor and aluminium flange with 6 pins. Brembo monobloc radial callipers with 4 Ø 34-mm opposite. Sintered pads. Radial pump and metal braided brake hose Rear: 220-mm diameter disc; Brembo calliper with two Ø 32 mm separate pistons. Sintered pads. Pump with integrated tank and metal braided hose
Wheels: Front: Aluminium alloy with 6 split spokes, 3.5”X17” Rear: Aluminium alloy with 5 split spokes, 6”X17”
Dimensions: Max. length: 2040 mm Max. width: 735 mm (at the handlebar) Max. height: 1120 mm Min. height from the ground: 130 mm Saddle height: 845 mm Centre to centre distance: 1420 mm Trail: 105 mm Steering angle: 24.5°
Dry weight: 184 kg *
Other: * Kerb weight, without battery and fluids.
ja ja ..tänkte höra iallafall vad ni använder för pipa på era RSV4 då jag inte kan hitta en enda handlare som säljer den gamla Leovince Evo II Full Titanium Can with Carbon End Cap Slip On Exhaust (8153).
hallå,
ska själv inhandla mig en rsv4 till våren....
så en fråga , är det värt de extra kr att lägga på en factory ?
blir som högst lite motionsåkande på bana, inget avancerat.... :)
Köp en efter 2011 så du åtminstone får sachs fjädringen och inte den gamla showa.
Köpte en Mivv på Louis.de Låter klart gött, borde nog faktiskt gå en runda bland grannarna och skramla lite pengar, de får ju njuta alldeles gratis nu.......
Så nu har jag beställt en SC-project pipa i titan!
vänTA VÄNTA VÄNTA .... AHHHH JOBBIGT !!!
Jag kör med Akra dock bara slipon låter mindre än orginal med db killern monterad.
Svingar upp bilderna igen ,
    62.9 KB · Visningar: 320
    51.6 KB · Visningar: 271
    30.2 KB · Visningar: 252
Tjo.. då var premiärturen avklarad!
Då har givetvis ett nytt bekymmer uppdagats.
Hur gör ni andra det med lås??
Vad använder ni för lås när ni är ute och kör. Och hur transporteras det.. finns ju ingenstans att ha låset, just nu får jag ha det i en midjeväska!
Nice... eller hur :D
Enkelt med låset :tummenupp
Lämna låset hemma och håll hojen rullande, lämna den inte en sekund med blicken :fakta
Hahaha jo visst var det nice,
Får väll bli magväska de gånger man vet man ska ställa den ifrån sig
Gjorde en liten hållare av två mm rostfri plåt som jag skruva fast i bakramen vid ljuddämparfästet. Ett hål i plåten och en ditsvetsad rörstump som skivbromslåset går i utan att studsa rundor.
Då har man invigts i apriliafamiljen(första turen)!
Måste säga att jag är imponerad av hur hårt den drar från låga varv samt hur otroligt liten och lätt den är! Dock så undrar jag om det finns en enda normal människa som kommer ner bakom originalrutan? Jaja som tur är ligger det redan en dubbelbubbel från puig i garaget och snart anländer även krascpuckar samt skylthållare från samma märke :D
Ska snart beställa en bazzaz Z-fi tc då jag inte har aprc och sen blir det nog ett leovince slipon och även ett par gilles rearsets :yoparty
Vinnn en CTEK CT5 Powersport!
Vinnarhjälmen utlämnad
