Wheelieboy90
Riktigt gött köra idag! Tack för wheelietipsen, men jag tror jag överlåter Ron Jeremy-varianten till er som kan...![]()
hahaha
Jag ska ut imorgon vid tre tiden imorgon förhoppningsvis! Nån mer som är sugen på en söndags bus?
hoppa på RR:en och ge järnet. 3h T/R
Verkar vara sista chansen för fint väder hela dagen -
så jag dra en runda över bron med diverse fikastopp
innan det bär strandvägen tillbaka till helsingør/hbg![]()
Hide a GPS in a hollowed-out PS3 to find your stolen items
There’s nothing worse than coming home one day, only to find that the majority of your valuables are missing. First, you’re hit with feelings of disbelief, then anger at those who now have your possessions. Of course, the most important thing now is getting your items back. But how are you going to find them? One method is to trick them into stealing a GPS tracking device.
How in the world are you going to make sure that a thief grabs your secret tracking device? That’s easy, you just disguise it as a high-ticket piece of electronics. One hacker decided to use the shell of a PS3 that he purchased online, then rigged up a GPS inside of it. The GPS uses an accelerometer to detect whether or not it has been moved. If it has, then the next time the unit is plugged in, it will send out a text with GPS information. You can also send a message to the device at any time, and it will respond back with the current location. This is definitely one of the more clever ways to keep track of your belongings.
Detta måste ju vara en grej för dig javaguru
http://www.redferret.net/?p=29238
Eller varför inte ha en iPhone liggandes intill med Find My iPhone aktiverat.
