Yamaha R1 2012
Jag som väntade på mycket annat.. känns som en "facelift" bara.. inget nytt egentligen när man kollat detaljerna.. TCSen iofs?
ENGINE
Type
998cc, liquid-cooled 4-stroke DOHC 16 valves (titanium intake valves)
Bore x Stroke
78.0mm X 52.2mm
Compression Ratio
12.7:1
Fuel Delivery
Fuel Injection with YCC-T and YCC-I
Ignition
TCI: Transistor Controlled Ignition
Transmission
6-speed w/multiplate slipper clutch
Final Drive
#530 O-ring chain
CHASSIS
Suspension / Front
43mm inverted fork; fully adjustable, 4.7-in travel
Suspension / Rear
Single shock w/piggyback reservoir; 4-way adjustable, 4.7-in travel
Brakes / Front
Dual 310mm disc; radial-mount forged 6-piston calipers
Brakes / Rear
220mm disc; single-piston caliper
Tires / Front
120/70ZR17
Tires / Rear
190/55ZR17
DIMENSIONS
Length
81.5 in
Width
28.1 in
Height
44.5 in
Seat Height
32.8 in
Wheelbase
55.7 in
Rake (Caster Angle)
24.0°
Trail
4.0 in
Fuel Capacity
4.8 gal
Fuel Economy**
33 mpg
Wet Weight***
454 lb
OTHER
Primary Reduction Ratio
65/43 (1.512)
Secondary Reduction Ratio
47/17 (2.765)
Gear Ratio - 1st Gear
38/15 (2.533)
Gear Ratio - 2nd Gear
33/16 (2.063)
Gear Ratio - 3rd Gear
37/21 (1.762)
Gear Ratio - 4th Gear
35/23 (1.522)
Gear Ratio - 5th Gear
30/22 (1.364)
Gear Ratio - 6th Gear
33/26 (1.269)
Warranty
1 Year (Limited Factory Warranty)
New for 2012:
•Seven-level Traction Control System allows the rider to get more traction and drive while exiting corners.
•New ECU settings provide excellent drivability during low and mid rpm acceleration.
•New top triple clamps add to the appearance of the YZF-R1, reminiscent of the MotoGP® powerhouse YZR-M1.
•The footrests have been redesigned for great boot sole contact and advanced rider/motorcycle interface.
•New headlight cowl styling and LED position lights enhance the YZF-R1’s unique styling.
•New silencer heat guards and end caps are re-styled to give the rear end of the bike a more compact look ,while at the same time making the individual parts look more mechanical.
Är motorn oförändrad? Fortfarande crossplane?
Japp.
"•Crossplane crankshaft technology proven in victory after victory on MotoGP® machines provides a high-tech uneven firing interval. Unlike typical inline-four engine design, where the two outer and two inner pistons move together in pairs with 180°intervals, the crossplane crankshaft has each connecting rod 90° with a unique firing order of 270° –180° – 90° – 180°. This overcomes the inherent fluctuations in inertial torque during each engine revolution, and the accompanying peaky torque characteristics. Instead, combustion torque continues to build, giving the rider more linear throttle response with awesome power and traction out of the corners."
Video om 2012:an
http://www.yamaha-motor.com/sport/products/modelvideo/6/1149/0/video.aspx
snygg! men blafforna till ljuddämpare förstör ju hela hojen
Akrapovic borde vara original på R1orna
Same same, R1-crossplanecrankshaft 2011 a.k.a. tjockpråmen, vinner ju inte ens i Pro Superbike lr i IDM!! Vem vill ha en sån då...EGENTLIGEN?! :arsele
jag hänger upp mig på att den inte erbjuds med ABS, och att priset är för högt. Undrar vad den nya FZ1:an kommer att ha för "nya" features. Typ nya färger och ny ECU-map
Nu hamnade den i rätt tråde med =) Rätt gott utan piporna däruppe ja!
Nu skall vi se, följande färger kommer finnas i Sverige.
Den sista är en Anniversary färg.
    100.1 KB · Visningar: 60
    96.3 KB · Visningar: 61
    122.6 KB · Visningar: 64
    112 KB · Visningar: 61
Sen har vi USA färgerna...
Borde inte den med grafiken kunna fungera här med... :va
    118.7 KB · Visningar: 90
    127.6 KB · Visningar: 70
    109.1 KB · Visningar: 113
Alltid redo för regn
