Rasorblade
Funderar på att köpa en 530 och motardkita
Borde finnas fler som har gjort det..
Engine
Engine type Single cylinder, 4-stroke
Displacement 510.4 cc
Bore x stroke 95 x 72 mm (3.74 x 2.83")
Compression ratio 11.9:1
Starter/Battery Kick- and electric starter/12V 4Ah
Transmission 6 gears
Carburetor Keihin FCR MX 39
Control 4 V/OHC with rocker levers
Lubrication Pressure lubrication with 3 oil pumps
Engine lubrication Motorex, SAE 10W50
Transmission oil Motorex, SAE 10W50
Primary drive 33:76
Final drive 15:45 (13:50)
Cooling Liquid cooled
Clutch Wet multi-disc clutch, operated hydraulically
Ignition Kokusan digital
Chassis
Frame Central double-cradle-type 25CrMo4 steel
Subframe Aluminium
Handlebar Neken, Aluminium Ø 28/22 mm (1.10/0.87")
Front suspension WP USD Ø 48 mm (1.89")
Rear suspension WP PDS shock absorber
Suspension travel front/rear 300/335 mm (11.81/13.19")
Brakes, front/rear Disc brakes Ø 260/220 mm (10.24/8.66")
Rims, front/rear 1.60 x 21"; 2.15 x 18" Excel
Tires, front/rear 90/90-21"; 140/80-18"
Chain X-ring chain 5/8 x 1/4"
Main silencer Aluminium
Steering head angle 63.5°
Wheel base 1475 ± 10 mm (58.0 ± 0.39")
Ground clearance (unloaded) 380 mm (15")
Seat height 985 mm (38.78")
Tank capacity approx. 9.5 liters (2.51 gal)
Weight (no fuel) approx. 113.9 kg (251,10 lbs)
Serviceintervaller
Vid 15 timmar:
Olje byte & Oljefilter
Kolla ventilerna?
Motardfälgar
Fälgar med 26mm axel fram och 20mm axel bak. Tror att alla fälgar från gamla LC4:an passar (624/640/660 årsm.03-05)
Ställa ventiler själv
http://paochow.com/forum/index.php?topic=40.0
Eftermarknadssavgasystem
Leo vince
Lexx slip-on
FMF
Akrapovic
CRD
Manualer:
http://www.ktm.com/download.php?dataID=8503H4_OM_EN.pdf Owner's Manual 2008
http://www.ktm.com/download.php?dataID=8503I4_OM_EN.pdf Owner's Manual 2009
http://www.ktm.com/download.php?dataID=8503J6_OM_EN.pdf Owner's Manual 2010
Engine
Primary drive 33:76
Chassis
Subframe Aluminium
Serviceintervaller
Vid 15 timmar:
Kolla ventilerna?
Motardfälgar
Leo vince
Lexx slip-on
FMF
Akrapovic
CRD
Manualer:
. Antar att du inte behöver svar på de du fråga i mailet längre då
