Ktm 530 exc-r/smc
Rasorblade
3 May 2003
Skitidedu
KTM 790 Duke
Funderar på att köpa en 530 och motardkita :yoparty
Borde finnas fler som har gjort det.. :va
Engine
Engine type Single cylinder, 4-stroke
Displacement 510.4 cc
Bore x stroke 95 x 72 mm (3.74 x 2.83")
Compression ratio 11.9:1
Starter/Battery Kick- and electric starter/12V 4Ah
Transmission 6 gears
Carburetor Keihin FCR MX 39
Control 4 V/OHC with rocker levers
Lubrication Pressure lubrication with 3 oil pumps
Engine lubrication Motorex, SAE 10W50
Transmission oil Motorex, SAE 10W50
Primary drive 33:76
Final drive 15:45 (13:50)
Cooling Liquid cooled
Clutch Wet multi-disc clutch, operated hydraulically
Ignition Kokusan digital
Chassis
Frame Central double-cradle-type 25CrMo4 steel
Subframe Aluminium
Handlebar Neken, Aluminium Ø 28/22 mm (1.10/0.87")
Front suspension WP USD Ø 48 mm (1.89")
Rear suspension WP PDS shock absorber
Suspension travel front/rear 300/335 mm (11.81/13.19")
Brakes, front/rear Disc brakes Ø 260/220 mm (10.24/8.66")
Rims, front/rear 1.60 x 21"; 2.15 x 18" Excel
Tires, front/rear 90/90-21"; 140/80-18"
Chain X-ring chain 5/8 x 1/4"
Main silencer Aluminium
Steering head angle 63.5°
Wheel base 1475 ± 10 mm (58.0 ± 0.39")
Ground clearance (unloaded) 380 mm (15")
Seat height 985 mm (38.78")
Tank capacity approx. 9.5 liters (2.51 gal)
Weight (no fuel) approx. 113.9 kg (251,10 lbs)
Serviceintervaller
Vid 15 timmar:
Olje byte & Oljefilter
Kolla ventilerna?
Motardfälgar
Fälgar med 26mm axel fram och 20mm axel bak. Tror att alla fälgar från gamla LC4:an passar (624/640/660 årsm.03-05)
Ställa ventiler själv
http://paochow.com/forum/index.php?topic=40.0
Eftermarknadssavgasystem
Leo vince
Lexx slip-on
FMF
Akrapovic
CRD
Manualer:
http://www.ktm.com/download.php?dataID=8503H4_OM_EN.pdf Owner's Manual 2008
http://www.ktm.com/download.php?dataID=8503I4_OM_EN.pdf Owner's Manual 2009
http://www.ktm.com/download.php?dataID=8503J6_OM_EN.pdf Owner's Manual 2010
Har ju min motsvarighet, 505 men samma skit nästan...
Får väl sätta dit mina halvorangea fälgar så den påminner om den ena du var sugen på ;)
    164.3 KB · Visningar: 536
Jag köpte en i tisdags så har bara provkört den fram och tillbaka på en gata. Kolla garaget för bild ;)
Behöver tips på avgas samt regskylthållare!:tummenupp
DAMN YOU!!! jag ringde på den dagen efter:gnissla:rolleyes::D
får provköra den då!!:Bugar
Ringde på den dagen efter den kom ut, åkte ner på fredagen. Kunde inte bestämma mig så åkte hem. Åkte dock ner igen och hämta den :yoparty
Så fort vädret tillåts ;)
Ska sätta ktm/wp-dekaler på framgaffel, fixa reghållare och avgas så e den perfekt!:banana
Tror allt i chassiväg passar, olika motorer mellan cross och enduron så avgassystemet passar inte tydligen
(Så nu i rätt forum)
Verkar vara några kända fel på 530
dessan fel har jag hittat iaf
Kamkedje sträckaren krånglar
Startmotorn verkar vara klen
Autodekompen kan strula
Någon som vet vad för uppdateringar som gjordes mellan 08-09 samt om det kommer några nya 10 ?
annars får jag kolla om man hittar något bra ex. eller fortsätta leta efter en bättre beggad 525:a
De gillar vi :tuttar. Antar att du inte behöver svar på de du fråga i mailet längre då ;)
Stylingtips får du gärna dela med dig, speciellt skylthållaren :)
Nope det är löst! Tack i all fall!
Skylthållare skiter jag i. Vet att det finns en på karlstrommotor.com. Jag sätter min i hjulhuset eller längst ut.
Min ska bli vit...:yoparty:Bugar
    214.6 KB · Visningar: 836
Om detta nu blir en ktm 530 tråd så skriv gärna hur service intervaller och sånt är på en 530.
Den frågan kommer säkert komma 1000 gånger igen också :)
Fruktansvärt snygg är dom iaf.
15h om den går som enduro och ca 8h omden går på gata :)
Skullys hoj på supermotojunkie om jag inte ute och cyklar. Fin ;)
Mmmmm den e så jevla cool!!:Bugar
Nya idéer för tvåtaktsmotorn
Förarkurser på Nürburgring
Brembo presenterar TrackTribe
