Ska sanningen fram så tror jag att det bla är pga av såna här fattiga självgoda humorlösa monologer som jag tycker att Topgear är så sövande att titta på.
Jag känner mig på ngt vis tidsbestulen efter att ha tragglar igenom text likt nedanstående. Man letar efter ngn skoj twist bakom den uppenbara skoltidningshumorn.... men finner ingen.
"A word of warning, though. If you use only the front brake, you will fly over the steering wheel and be killed. If you try to use the back one, you will use the wrong foot and change into third gear instead of stopping. So you’ll hit the obstacle you were trying to avoid, and you’ll be killed.
Then there is the steering. The steering wheel comes in the shape of what can only be described as handlebars, but if you turn them — even slightly — while riding along, you will fall off and be killed. What you have to do is lean into the corner, fix your gaze on the course you wish to follow, and then you will fall off and be killed."
