En tjuga bjudet rakt över disk!![]()
Taget. Bättre att någon på sh får den billigt än att den bara står och samlar damm
Bara att svänga förbi och plocka upp. Filmen är oanvänd, dock utan skyddsplast.
Årets spel 2007 lär bli detta;
Uncharted
Trailer -> http://www.gametrailers.com/player.php?id=19736&type=wmv
On stage demo -> http://www.gametrailers.com/player.php?id=19633&type=wmv
Taget. Bättre att någon på sh får den billigt än att den bara står och samlar damm![]()
Blazing Angels - Squadron of WWII kan man nog slösa bort X antal timmar på =P riktigt tufft men tror det e ändå ballare online 12 pers Co-op tex 12 pers i Pearl harbor kan nog vara rätt skoj =P
Förresten vad heter ni på Ps3 online?
PS3 Firmware Version 1.80 Announced
Latest PLAYSTATION 3 Firmware Update Provides PlayStation, PlayStation 2 and DVD Upscaling
Remote Play on PSP (PlayStation Portable) via the Internet and DLNA transfer of media content also enabled
London, 24 May 2007 ? Sony Computer Entertainment Europe (SCEE) announced today availability of the latest version of the PLAYSTATION®3 (PS3?) firmware. Version 1.80 features upscaling of PlayStation® and PlayStation 2 games, and DVD movies up to full 1080p HD resolution when viewed on a compatible HD TV set.
The capability to upscale DVDs to HD quality is a feature normally only associated with top range DVD players, and its inclusion in the latest firmware upgrade now allows PS3 owners with an existing DVD collection to dramatically enhance the viewing pleasure of their DVD collection when viewed through a compatible HD TV set1. Not only can DVD movies be enhanced to full 1080p HD quality but so too will PlayStation 2 and PlayStation games be upscaled to provide much improved gaming pleasure.
In a comprehensive update to PS3?s already impressive capabilities, Version 1.80 also allows users to enjoy Remote Play on their PSP across the internet, allowing them to access their PS3 anywhere in the world where a broadband internet connection is available2.
Version 1.80 also allows users on a home network to seamlessly view and play rich media content such as images, music and video on their PS3, that is stored on their DLNA3 enabled devices such as PCs and laptops elsewhere in the house, reinforcing PS3?s credentials as a home entertainment hub that truly deserves pride of place in the Living Room.
A host of other enhancements include the ability to print photo images stored on PS3?s hard disk or inserted storage media to a selection of Epson printers.
PS3 owners will be able to upgrade their PS3 with the latest Version 1.80 firmware from 24th May 2007.
Synd bara att det har en tendens att lagga vid explosioner. Helst när man skjuter sönder flera ballonger samtidigt i träningsbanan från början. Men annars ett rätt underhållande spel måste jag säga.
Jag heter Swebreeze på PSN.
Här kommer goda nyheter för oss PS3-ägare! FW 1.8 ute nu!![]()
http://www.fz.se/nyhetsarkiv/?id=19712
Ngn som har kommt undetfund med streamningen från ps3,an?
Jodå, använder Windows Media Player 11 men dock har jag inte fått Mp3 att fungera.
Använder man Nero Media då kan man tom titta på avi!![]()
Ofan men hur får jag igång det? jag får ta o börja med o tanka WMP11 så =P
DLNA is an industry standard for media (audio,video, photo) sharing within concept of a digital home and is supported by many hardware and software manufacturers. As of FW1.80, DLNA is supported by Playstation 3 entertainment system. PS3 takes a role of DLNA Player, not DLNA server, so it can play a content of any DLNA server (source) in you digital home, but can not stream the content to other players within DLNA protocols. (Remote connect to PSP is using proprietary protocols)
What it means is that you have to have a DLNA server installed, either hardware (like some HDD storages, DVRs or set-top boxes) or as a software on your PC.
The latter is most interesting for majority of us, since DLNA certified CE equipment is not that widespread yet.
Your options for the software naturally depends on your operating system. DLNA is an open protocol based on UPnP (Universal Plug and Play) and therefore can work on any operating system. So far we found a reasonably good solution only for Windows OSes, so I'll start with it.
Windows
WMP11
If you are running Windows Vista you have a very simple way to enable the sharing through Windows Media Player 11. If you search in Media Sharing Tab
you can spot a new unknown device you can share media to:
If you don't see the device, the chances are that a)you have a firewall blocking WMP11 media sharing b) there is some port conflicts between ps3 and your home network. Disable firewall to check if its a), or restart your PS3 (or disable and enable back media sharing in XMB under Network Settings). After each reboot PS3 will use different set of ports for media sharing, so eventually you should be able to get PC and PS3 see each other. The same also applies to a similar problem with other software.
But most users should see the unknown device in media sharing right away. Allow sharing to it and go to your PS3. Now, after 1.80 the new icon appeared in Music/Video and Photo bars, called Search for Media Servers. Click it and if you are lucky, a Vista media server icon will appear just under it. Now you can click on it and navigate through you WMP11 library direct in XMB!
Moreover, hit triangle on your video file and you can copy it over to PS3 without hassle!
According to Microsoft, it should also work for WMP11 under XP:
http://www.microsoft.com/windows/win...haremedia.aspx
If you have a problem with it under XP, try to manually enable UPnP service. For this do the following:
Click Start
Click Programs
Click Administrative Tools
Click Services
Scroll down to Universal Plug and Play Device Host
Double click Universal Plug and Play Device Host
Set the Startup type to Automatic and click the Start button in that window to start the service
If you don't see the Administrative Tools in the Programs you will need to right mouse click down in your taskbar and go to Properties, from there click the Start Menu tab and click the Customize... button, just check Display Administrative Tools and then click OK.
So, WMP11 sounds good, right? Its not that perfect however, since you will be only play video and music files that are supported by PS3, and in some cases not even all of them. And that limits you to MP2 and MP4 (which reported to not work at some cases), so no luck with AVIs.
The only solution here is transcoding, which is basically on-fly recoding of source video/audio to target video/audio. The best (and only correctly working so far) program for it is Nero MediaHome, which is a part of Nero Digital Pro package: http://www.nero.com/eng/Upgrade_to_N...gital_Pro.html
Thanks to mingeeta@PS3forums we have a quick tutorial for setting it up.
Turn your PS3 on and login, and leave it on your XMB
Run a file in Nero Showtime to unblock the firewall that pops up and ALLOW.
Run Nero MediaHome
On the left are a set of Icons.
Heres a quick setup:
SHARED DIRECTORIES > Click ADD SHARE and browse to a single shared directory for now, as it takes time to add the details, so dont go adding gazillions of media files for now.
OPTIONS: I left them at default for now, but they are self explanatory. Automatically start media home when pc is switched on is a good one to tick up, but leave it off for now till you get it going.
NETWORK: Click the box for your ethernet card on your PC. Leave port number and network name at default for now
DEVICES: Click UPnP/1.0 line and click ALLOW ACCESS box
TRANSCODING: Leave on auto detect as it will talk to the ps3 and see what it can and cant play and come up with a solution after a few seconds.
TV: Set up your tv card here
STATUS: Click this ICON and you will be able to see whats going on
then click START SERVER at the bottom, and you wait a few moments. Go back to PS3 and it should show the Nero Media Home Icon. Browse as normal for your video files.
At first if you have loads of files in your shared directories it can cause the ps3 playback to come back out to the XMB. Just give Media Home some time to update the directory listings, then it will be silky smooth.
It was tested at a decent PC for SD avi files only so far, and they work fine. You might have issues if you have an old pc, as the transcoding can take up resources.
If you cant see any media on your PS3 after doing all this, try following:
Turn off the server and go to TOOLS - NERO SCOUT - INDEXING - FOLDERS and select the folders you want there. Then go back to the INDEXING tab and click INDEX NOW - this may take a while to do, if you have huge amounts of files, so as before just to get it working. When its done go to SHARED DIRECTORIES ICON in nero media home and select SHARE ALL CONTENT INDEXED BY NERO SCOUT
As it seems now it works quite fine for SD content, but stutters/fails at HD files, which is not surprising, giving the needed processor power for on-fly HD conversion.
If you have a problem with full version of Nero MediaHome within Nero 7 or Nero Digital Pro packages, you can try Nero MediaHome CE, which is using code optimized for consumer electronics devices: http://www.nero.com/nerodigital/eng/download.php
Its smaller, faster and seems to produce good streaming results. It also smart enough to stream HD mp4 files without transcoding to PS3. Drawback is that you don't get automatic thumbnails with it, as far as I can see.
For native HD MPEG2 files people are getting good streaming results with twonky vision media center http://www.twonkyvision.com/ but as of current it full of glitches when working with PS3, so I wouldn't recommend you to spend much time with it until they deliver a patch specifically for PS3. Same can be said about another popular DLNA streaming/transcoding solution TVersity http://tversity.com/.
UPDATE: Twonky Vision released a 4.4 Beta 1 version of Media Server with PS3 support!
http://www.twonkyvision.com/Download...index-4-4.html
Users are reporting correct streaming of H.264, some MPEG4 video and MP3. AAC sound is still not supported it seems. If you are not in love with WMP11, its a viable alternative now.
UPDATE: Patch for TVersity with support of FW1.80 is released! Get it here:
http://tversity.blogspot.com/2007/05...ny-ps3-is.html
After few iterations of this patch TVersity is now VERY viable option, especially because its free. With proper configuration you can stream anything from WMV to XViD with a decent quality (limited only by your PC power and connection speed). Installation of it is rather straightforward, I'll just try to cover some most common problems that people encounter with it:
TVersity
First, you NEED ffdshow installed. Best results obtained with ffdshow rev. 802.
http://sourceforge.net/project/downl...d.exe&42211223
If after the installation of TVersity AND ffdshow you still get unsupported type of error, consider downloading Graphedt.exe:
http://www.digital-digest.com/dvd/do...hedit_141.html
It will show you in detail whats going on with your video and were the problem is. If this program plays your video on PC fine, but not on PS3, then you have an access/permission somewhere. One of the common problems - running tversity media server service not under account with administration rights. To check it do the following - stop sharing in tversity. Go to tversity folder and run "mediaserver.exe -debug" . Try again if you can stream. If you do - set your mediaserver service to use admin logon (its under administration tools/services/).
If you still fail - its a firewall/router problem then. As reported in this thread, some were able to get it working by disabling windows media network sharing service on firewall.
Still have problems? Make sure you have ffdshow doing decoding for you, not other codecs. Easiest way is to check the settings of ffdshow and set it as a default decoder for all formats. It is also asked in the end of ffdshow installation.
Once you get basic avi streaming working, you can try to install additional filters to increase performance or add additional formats. Here is what recommended by tversity guys:
* ffdshow - for MPEG2/4, H.264, Divx, Xvid, AAC, FLAC, Vorbis, FLV, and many more
* Haali Media Splitter - for better MP4 and H.264 support and for OGG/OGM and Matroska.
* Real Alternative - for Real audio and video.
* Quicktime Alternative - for MOV.
* MP4 Source/Splitter* - for better MOV support.
* FLV Splitter* - required for FLV playback (a more recent version with support for FLV4/VP62 is here - courtesy of videohelp.com).
* AC3 Filter - recommended for better AC3 support (in which case AC3 should be disbaled in ffdshow).
But only get into it when you get your basic playback working.
By default, TVersity recodes everything to MPEG1, dont be surprised. MPEG2 and 4 much more demanding in terms of PC power for recoding, and, while you change the recoding to mpeg2, for example, it still do not work properly with current version of tversity, do not bother.
There are also a bunch of freeware UPnP software that should allow streaming to PS3 as well, such as:
http://www.gnu.org/software/gmediaserver/
http://ushare.geexbox.org/
http://mediatomb.cc/
http://www.cybergarage.org/net/cmgate/cc/index.html
You can look at them if you have enough free time and some skills. Most of them can also be compiled to Mac or Linux, but I wouldnt try to do it without massive amount of free time.
Speaking of other OSes, Mac users theoretically also have a number of options.
Mentioned above Twonky Vision Media Center has OsX version available, and you can give it a try.
UPDATE: Twonky Vision Media Server v4.4 Beta 1 for Mac now officially has PS3 support!
Exclusive to Mac systems is EyeConnect software http://www.elgato.com/index.php?file...cts_eyeconnect
both have 30days free trials, so its plenty of time to try. I don't have a Mac personally, so I cant check. But with EyeConnect users reporting that audio works pretty much perfect, including iTunes library, but video has more problem, though some users claims that MPEG and MPEG2 streaming do work, just no transcoding. Again, a necessary patch shouldnt be a way off, its just that with FW 1.80 Sony really caught everyone off guard.
Linux users normally advanced enough to know more about it than me, I will not elaborate here. Freeware programs posted about + twonky media server should be usable.
EDIT: MediaTomb released patch recently that made streaming possible under Unix. Read more on the matter here: http://www.neogaf.com/forum/showpost...&postcount=440
At the end, as a general note, most common mistakes so far:
1) firewall (either PC firewall or in router) blocking a media server program (thats when you can find a media server after search on your PS3)
2)you are looking for video files in Music tab of XMB. Though sometimes they may be there, but its a bug. DLNA normally should take care that you see videos only under video tab and pics under Photo. .)
I samband med MotoGP-racing... |
Sveriges MotorCyklister (SM... |
Norton Motorcycles siktar på fyra nya modeller till 2026
Norton Motorcycles förbered... |
Nu är det klart att världen... |
Honda var tillbaka i Biarri... |
En hyllning till mästaren!
Pressrelease från MV Agusta... |
I nästa nummer av Allt om M... |
Testhoj hämtas från Sulas MC
Vi åkte till Strängnäs för ... |
Foto: Andreas Johansson ... |
