Skillnad mellan hund och katt
Deimos
Våga vägra latinska citat.
15 Mar 2003
Malmö
Yamaha XJR1300 SP
HOW TO GIVE A CAT A PILL...
1. Pick up cat and cradle it in the crook of your left arm as if holding baby. Position right fore-finger and thumb on either side of cat's mouth and gently apply pressure to cheeks while holding pill in right hand. As cat opens mouth, pop pill into mouth. Allow cat to close mouth and swallow.
2. Retrieve pill from floor and cat from behind sofa. Cradle cat in left arm and repeat process.
3. Retrieve cat from bedroom, and throw soggy pill away.
4. Take new pill from foil wrap, cradle cat in left arm, holding rear paws tightly with left hand. Force jaws open and push pill to back of mouth with right forefinger. Hold mouth shut for a count of ten.
5. Retrieve pill from goldfish bowl and cat from top of wardrobe. Call spouse to help hold cat.
6. Kneel on floor with cat wedged firmly between knees, hold front and rear paws. Ignore low growls emitted by cat. Get spouse to hold head firmly with one hand while forcing wooden ruler into mouth Drop pill down ruler and rub cat's throat vigorously.
7. Retrieve cat from curtain rail, get another pill from foil wrap. Make note to buy new ruler and repair curtains. Carefully sweep shattered figurines and vases from hearth and set to one side for gluing later.
8. Wrap cat in large towel and get spouse to lie on cat with head just visible from below armpit. Put pill in end of drinking straw, force mouth open with pencil and blow down drinking straw.
9. Check label to make sure pill not harmful to humans, drink 1 beer to take taste away. Apply Band-Aid to spouse's forearm and remove blood from carpet with cold water and soap.
10. Retrieve cat from neighbor's shed. Get another pill. Open another beer. Place cat in cupboard, and close door on to neck, to leave head showing. Force mouth open with dessert spoon. Flick pill down throat with elastic band.
11. Fetch screwdriver from garage and put cupboard door back on hinges. Drink beer. Fetch bottle of scotch. Pour shot, drink. Apply cold compress to cheek and check records for date of last tetanus shot. Apply whiskey compress to cheek to disinfect. Toss back another shot. Throw Tee shirt away and fetch new one from bedroom.
12. Call fire department to retrieve the damn cat from across the road. Apologize to neighbor who crashed into fence while swerving to avoid cat. Take last pill from foil wrap.
13. Tie the little bastard's front paws to rear paws with garden twine and bind tightly to leg of dining table, find heavy-duty pruning gloves from shed. Push pill into mouth followed by large piece of filet steak. Be rough about it. Hold head vertically and pour 2 pints of water down throat to wash pill down.
14. Consume remainder of scotch. Get spouse to drive you to the emergency room, sit quietly while doctor stitches fingers and forearm and removes pill remnants from right eye. Call furniture shop on way home to order new table.
15. Arrange for SPCA to collect mutant cat from hell and call local pet shop to see if they have any hamsters.
HOW TO GIVE A DOG A PILL..
1. Wrap pill in bacon.
2. Toss it in the air.
3. Get out of the way.
Fan, du påminde mig nyss om att jag ska börja ge lillkatten p-piller :(
En annan skillnad:
Hunden tänker: Den där personen ger mig mat, alltså måste den där personen vara Gud.
Katten tänker: Den där personen ger mig mat, alltså måste JAG vara Gud.
katter är antingen jäkligt dumma eller jäkligt smarta - men oavsett så är de lata och otrevliga.
Min lillebror har gaggat om att skaffa katt i evigheter. Förra veckan var det någon patients katt på mammas jobb som blev utan ägare och katten kunde inte bo kvar där den var så den skulle avlivas.
Brollan var skitglad att han kunde ta hand om den och sprang ut o köpte saker för bortåt 1500 spänn för att kissen skulle må bra.
Katten var en 4 åring kastrerad hane.
I söndags vaknade min lillebror av att katten river honom på handen, biter honom i PANNAN :va och får spatt och pressar sig ut genom en fönsterspringa som var minimal för att inte mer återkomma.
Och folk vill förbjuda hundar? (:tungan )
Personligen skall jag ha hund :yoparty
Det sköna med katter är ju just när de freakar! En fet långhårig katt som ligger och fiser är ju inge kul. Vi hade en burma/bondkattkorsning som hängde på väggarna. Den tog en svala som flög in när hon bara var 7 veckor! Fågeln var dubbelt så stor.
hehe, lite småkul:D
brudens katt är avtlå, har muckat med så pass mycket större katter att båda öronen har STORA revor i sig:yoparty dessutom är hon (katten alltså:tungan ) ombytlig som få! bruden har varit hemma hos mig en vecka, kommer hem, katten får syn på henne och blir, till en början, alldeles till sig: "duärhemmaduärhemmaduärhemmajagärsurpådig..." för att därefter ignorera i tre dagar:rofl
Världens skönaste djur helt enkelt. Har levt med både hund och katt men inget djur kan mäta sig med en katt helt enkelt.
Idag så målade jag och tjejen trappräcket ute i trapphuset och vår äldsta katt satt några trappsteg ovanför oss och bara kollade på när vi jobabde hela tiden, i ca 90 minuter. Därefter följde han oss in och sträckte lite på sig precis som att han var helt utmattad för att sedan gå och sova ett tag innan kvällsrycket som börjar vilken sekund som helst.
Och ja, han är ond. Precis som de ska vara. Bara lojal mot sin undersåte, dvs mig själv :D
Ähh, både hundar och katter har sin charm, morsan och farsan har både och.
Två katter, kullsyskon som är helt fucking galna, samt en liten Chinese crested powderpuff (folk som inte vet bättre säger att det är en liten kärringhund).
När allihopa får DAMP samtidigt då sitter man halvt panikslagen i soffan och småhukar, för då kan det komma en katt i 110 knutar springandes på soffryggen, tätt följt av en marginellt större hund som i sin tur torpederas i sidan av en annan lömsk katt som har suttit i bakhåll i bokhyllan.
Hunden kan ligga på golvet och tugga (kärvänligt) på kattens bakben i tio minuter, för att helt plötsligt åka på stordäng i 30sekunder av den andra katten som tycker att han vill vara med.
Dom är helt enkelt en outsinlig källa till glädje!
Ett hem utan husdjur är bara ett hus!
Gillar inte katter för mycket. Dom är lika lojala som en klamydiainfektion. Man kan ha en katt i flera år, ge den massa god mat, klappa den, låta den sova i den bästa fotöljen, klänga i gardinerna. Sen en dag glömmer man stänga terrassdörren och shwiiiisss så är den borta. Kanske kommer den hem några veckor senare när den blivit hungrig och behöver ladda batterierna, endast för att dra igen vid första chans.
Tacka vet jag hundar. Skulle det komma in en gangster i huset och attackera med en machete hade hunden kämpat till sista andetaget för att rädda husse.
Vad hade katten gjort. Antagligen tagit chansen när husse är upptagen för att hoppa upp i byrålådan och pissa ner samtliga kalsonger....:mad:
Jag är hundmänniska rakt igenom.. Katter är jobbiga, fula och tråkiga.
Det kan gå bra nån enstaka gång, i någon minut. Max.
Hundmänniska hela dagen, och min vovve är en riktigt hussehund :)
Katter är lömska och inte alls lika trogna som vovvar
Katter är normalt otroligt sociala djur mot de de håller närmast. Min katt var en lösspringare som jag adopterat. Han var väldigt skygg mot alla människor och tydde sig egentligen bara till mig, men det gjorde han istället med råge. Innan jag skaffade honom så trodde jag i stort sett att katter var djur som kom och gick som de ville och sket i allt och alla.
Jo, man hör ju ofta talas om taxar, chivavvor och dvärgpudlar som avvärjer machete-angrepp på sina ägare :D
:rofl
Min äldsta katt är mer som en hund. Jag brukar ha med honom ut till garaget på somrarna och då går han alltid lös och kommer så fort man ropar på honom och ska alltid följa med mig. Han blir nästan lite ängslig när han inte vet vart jag är.
Samma sak i sommarstugan, där är han med och kommer OFTAST när man ropar på honom om han inte anar att vi ska åka hem för då har han gått och gömt sig under lillstugan eller under båten :D
Sen bor jag centralt också men det hindrar inte från att han är med mig när jag står och fiskar vid ån eller dylikt, dock brukar jag låta honom gå i koppel om vi ska korsa vägar etc.
Men visst, att fostra en bondkatt är fan så mycket svårare och det vet jag av egen erfarenhet då jag har haft säkerligen 10-12st under mina år i livet.
Katter e trevligt, men de gäller att få en me rätt personlighet.
Min lille bubbe e så go så... medgörlig som få o så jävla rolig ibland :P..
Jag gjorde precis samma sak med en hittekatt som höll på att svälta/frysa ihjäl, trots att jag är kattallergiker, den blev otroligt social mot precis alla människor, speciellt husse och matte, den följde oss gåendes till kiosken, satt utanför tills vi hade handlat och följde oss hem.
Hon kom även när man ropade på henne, hon lärde sig massor av fåniga tricks, att räcka tass och sitta på kommando, men hon utförde dom bara när hon var busig/glad/pigg...
Hade hon en pissig dag så visade hon det.
Vi bodde så bra till att hon kunde komma och gå som hon ville, vi hade dörren på glänt hela sommaren, och ibland när vi kom hem hade hon bjudit in gårdens alla katter i lägenheten.
På vintrarna jamade hon när hon ville gå ut, och krafsade på fönstret när hon ville komma in.
Var hon ute på vintern och vi kom på att vi skulle åka bort så ropade vi in henne, hon kom direkt.
Om våra barn (när dom var små) började grina i sina sängar sprang hon dit och tröstade dom, annars sov hon på en egen kudde i sängen.
Fan vad jag saknar det lilla luddtrollet.
ja, jag vill inte äns tänka på dagen då min kisse inte finns längre...
det handlar ju faktist ganska mycket om personlighet. vi har en katt och 2 hundar. ena hunden är en riktig mammagris som är lite småskygg för allt utom just mamma, matkåt som fan och allmänt nervös. den andra Lurvas är så grymt mycket skönare man förstår direkt på hans kropskpårk vad han känner/ vad han vill.
Lurvas är super! :)
http://www.youtube.com/watch?v=jxLvrRrYpTY
nu är han dock 2 år äldre men han stätter fortfarande det där ;)
När jag har min katt hemma o går o lägger mig så kommer han o lägger sig på magen o kurrar o det välkomnar jag för de e mysigt...
När jag har kollegans schäfer hemma o går o lägger mig så kommer han o bökar me nosen o ska leka o fattar inte att de e läggdags, HUNDJÄVEL!..
