Shell.Application Fix - Viktig Fix
MulleMuck
Cepe med megafon
4 Dec 2003
Växjö
Yamaha TZR -99
About the same time Jelmer found the adodb bug, http-equiv
found a similiar issue with the object "Shell.Application".
This issue has also been unfixed for the past ten months.
Unfortunately, Microsoft has not taken the "hint" and not
fixed this issue either.
Jelmer has noted this and made a proof of concept exploit
page here:
http://62.131.86.111/security/idiots/malware2k/installer.htm
This registry file will protect you from this exploit
by kill biting "Shell.Application" variant.
Shell.Application is commonly used by administrators
for administration of systems via Visual basic script
or WSH. It may have other uses. It is kind of Microsoft's
answer to shell script -- though not as happy as batch.
RED LiME's Kommentar:
Har själv råkat ut för detta... Skulle in på en länk från mIRC som länkade till en
film (.avi), men jag fick virus i datorn som var jävligt jobbigt... Tror inte MS har patchat det än så ni kan ju patcha ifall ni har lust :P
Gör en .reg fil och klistra in detta:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ActiveX
Compatibility\{13709620-C279-11CE-A49E-444553540000}]
"Compatibility Flags"=dword:00000400
sen kör ni bara filen så ändrar den det i registret! :)
/SAXAT FRÅN ASTALAVISTA.COM/
Bästa bugfixaren för internet explorer finns här - den fixar ALLA problem med IE.
Custom Bike Show den 6e juni.
