Tack! Nu till frågan om .r01 .r02 osvMcB skrev:En .sfv får du fixa själv, det gör inte WinRAR åt dig. Ladda ner något som heter QuickSFV.
Aha så jag bara bygger in en "-vn switch"UrbanTiger skrev:Volumes are parts of a split archive. Volumes are supported only by the RAR archive format, so you cannot create ZIP volumes. Generally volumes are used to store a large archive on several diskettes or other removable media.
By default RAR volumes have names like 'volname.partNNN.rar', where NNN is the volume number. Using -vn switch it is possible to switch to another, extension based naming scheme, where the first volume file in a multi-volume set has the extension .rar, following volumes are numbered from .r00 to .r99.
Volumes may also be solid and self-extracting. The first self-extracting volume has a different (i.e. not .rar) file extension identifier, for example .exe for DOS SFX volumes.
It is impossible to add, update or delete files in created volumes.
To unpack volumes you need to start extraction from the first volume. If volumes are stored on non-removable media like a hard disk, you need to put all volumes in the same folder before starting extraction.
Innehåll Bike powered by... |
Shelby Turner, klar för GGN
Nya BMW S 1000 RR tar form
