Nu supermoto från BMW
Gnutten skrev:
2530050 Shit, skulle kunna tänka mig en BMW faktiskt!
Är det insprutning på den också, då det förmodligen är samma motor som i Scraver alt vanliga 650?
Är det någon som vet någon vikt på modellerna????
Hittade detta på bmw-motorrad.com. Håll till goda !!:tummenupp
Engine
Type Water-cooled, single-cylinder 4-stroke, four valves, two overhead camshafts, dry sump lubrication
Bore / stroke 100 mm x 83 mm
Capacity 652 cc
Rated output 39 kW (53 hp) at 7,000 rpm
Max. torque 60 Nm at 5,250 rpm
Compression ratio 11.5 : 1
Mixture control / engine management Electronic intake pipe injection / BMW engine management, twin spark ignition
Emission control Closed-loop 3-way catalytic converter, emission standard EU-3
Performance / Consumption
Maximum speed approx. 170 km/h
Fuel consumption per 100 km at constant 90 km/h 3.5 l
Fuel consumption per 100 km at constant 120 km/h 5.0 l
Fuel type Unleaded super, minimum octane rating 95 (RON)
Electrics
Alternator three-phase alternator 280 W
Battery 12 V / 10 Ah, maintenance-free
Power transmission
Clutch Multiple-disc clutch in oil bath, mechanically operated
Gearbox Constant mesh 5-speed gearbox integrated into crankcase
Drive Endless O-ring-chain with shock damping in rear wheel hub
Chassis / Brakes
Frame Bridge-type steel section frame with bolted-on cast aluminium side elements, bolted-on aluminium rear section
Front wheel location / suspension Upside-down front fork, Ø 45 mm, rebound and compression damping adjustable
Rear wheel location / suspension Cast aluminium dual swing arm, central spring strut, spring-preload and rebound damping manually adjustable
Suspension travel, front / rear 270 mm / 245 mm
Wheelbase 1,500 mm
Castor 98 mm
Steering head angle 61.5°
Wheels cast aluminium
Rim, front 3.50 x 17"
Rim, rear 4.50 x 17"
Tyre, front 120/70 H 17
Tyre, rear 160/60 H 17
Brake, front Single disc, floating brake disc, diameter 320 mm, four-piston fixed caliper
Brake, rear Single disc, diameter 240 mm, single-piston floating caliper
ABS Optional extra: BMW Motorrad ABS (can be switched off)
Dimensions / Weights
Length 2,155 mm
Width (incl. mirrors) 907 mm
Height (excl. mirrors) 1,180 mm
Seat height
Inner leg curve 900 mm (low seat: 880 mm)
1,940 mm (low seat: 1,900 mm)
Unladen weight, road ready, fully fuelled 1) 159 kg
Dry weight 2) 147 kg
Permitted total weight 335 kg
Payload (with standard equipment) 176 kg
Usable tank volume 9.5 l
Se där ja lite info fanns det!
Om det är samma rova som i scarvern och GS så går de jäkligt snålt.
Kommer bli intressant hur den står sig i ett test med t,ex XT660 mfl!
Roger_SWE skrev:
2531026 Ja nu börjar det likna något :tummenupp
En BMW-försäkring och det kan bli billigt nöje också.
/Roger
just de. tänkte jag inte på, lär ju bli billig som faen :tummenupp
nästan grattis om man jämför med nån annan hoj,
istället för o betala försäkring betalar man lån istället :tungan
Toppeffekten av 53 hästar levereras vid 7000 varv och det maximala vridet är 60 Newton vid 5250. 0-100 avverkas på 4 sekunder och toppfarten varierar mellan 165 och 170 beroende av modell.
Chassiet är byggt för att erbjuda maximal hanterbarhet och körglädje och därför har vikten hållits nere. Torrvikten är mellan 144 och 147 kilo.
faen..ganska fina fakta :tummenupp
detta med en katalysator mm..undrar om den går o plocka bort o få mer hk :yoparty
inte så tokig vikt heller :)
