Min sv650 klonkar också sådär... Har du skruvat åt än?
Han har byggt hus, fått 3 barn, gift om sig. Och har nu en Opel Astra.
Skämt å sido... skapligt trådlyft!
Mats
Referring to the sound of the front forks over small to large bumps...
The clunking that you hear when you go over bumps or hit the brakes too hard is coming from the steering bearings inside of what
looks like the frame on the front of your SV, what must be done to fix it is:
First, remove the triple tree, do this by loosening the two allan screws on either side of the tree, then remove the large nut on the middle of the triple tree, it is a 30mm nut, then carefully pull every thing off, the instrument cluster will come off with it, then you will see a round nut with three notches in it, you need to tighten that down with about five pounds of torque, put everything back on, and never hear the clunking again...
Email me, Nathan, with any questions regarding the process.
Good Luck!!!
Under 46:e Coca Cola 8-timm... |
Sandvikens franskaste Triumph
I Norrtälje kunde vi se hur... |
Den 2 augusti körde Hydet M... |
A ride for our child, Tyra
MC-kortegen ”A ride for our... |
Mälaren Runt #40 – 16 augusti
Lördagen den 16 augusti kör... |
Specialbyggd Yamaha XSR900 GP
För att fira den trefaldige... |
Den 7–10 augusti 2025 förva... |
Screenshot Den 16–17 aug... |
En vecka kvar!
Nu är det exakt en vecka kv... |
