Megafeta hojar!
Penguin
Helmet time is good time
Märsön
Vill ni olla på riktigt feta hojar ska ni kika på www.qbcarbon.com
Smakprov 1 är en Fireblade 954:a som byggdes inför Isle of Man.
Tekniska specifikationer:
·Lightweight carbonfibre bodywork styled on the CBR600
·Fully pressurised carbonfibre ram-airbox - built to Honda Japan spec
·Erion tuned 954cc 180 bhp engine with slipper clutch
·Promach adjustable yokes and rearsets
·WSB Spec Ohlins Suspension
·Brembo Monoblock Brakes - choice of 320mm or 290mm discs
·Micron Race exhaust with serpent headers
·Widened Swingarm with built in quick release wheel system
·Lightweight 5 spoke wheels with Dunlop slicks
·Dry Weight 162 kg
Tyvärr fanns inte bilderna i stort format...
    21 KB · Visningar: 325
    22.5 KB · Visningar: 132
    6.3 KB · Visningar: 178
    6.1 KB · Visningar: 179
    7.8 KB · Visningar: 177
Smakprov nr 2 är en MW Augusta i rejstrim!
Engine
·140bhp
·Balanced crank
·Raised compression
·Factory SPR cams
·Factory EPROM chip
·Custom built MotoGP exhaust
·Gas flowed cylinder head
·Reworked pistons
·Iridium spark plugs
·Large capacity ram-air duct (worth 3bhp)
·Free flowing airbox
·Magura clutch master cylinder
Chassis
·Magnesium wheels, swingarm, frame plates and bottom yoke
·Re-valved forks
·Ohlins rear shock
·Gilles rearsets
·PFM front brakes and master cylinder
·Serie Oro brake discs
·Dunlop slicks and D208GP tyre's
·Aluminum fairing brackets
·Carbon fibre MotoGP style fairing
·Carbon subframe
·Carbon seat unit, fairing support plates
·Carbon undertray, heel plates, hugger, front fender
·Twin filler endurance tank
·Magnets in calipers to hold pads back
·Forks machined to allow calipers to rotate
    15.6 KB · Visningar: 156
    3.7 KB · Visningar: 177
    5.1 KB · Visningar: 180
    5.8 KB · Visningar: 180
    5.4 KB · Visningar: 184
Fan, jag skulle juh skriva det första inlägget, YamahaJojje :huvet
QB Carbon Checa R1
The "Checa" bike originated from our R71 project and Grand Prix star Carlos Checa's R1, chassis modifications include the swinging arm being boxed in for extra strength and extended to improve stability, it also features the quick release rear wheel system as used by the top endurance teams, both swinging arm and frame are powder coated dark grey.
Front forks are R7 style Ohlins, while at the rear a R7 style piggyback shock is fitted. If you wish to be privileged to some really fast steering there is an option to fit Pro-Mach offset yokes as used by David Jefferies in his North West and TT winning V&M R1, the exact degree of the offset is a secret.
A QB ram air box is fitted with the Carbs set up by V&M Racing. A 21 litre QB carbon/kevlar fuel tank with twin filler is fitted along with a QB Grand Prix style fairing which features a R7 headlight and forward pointing air ducts which force air under the fuel tank, the rear of the bike features a all new Carbon/Kevlar design single seat with undertray, trick rear light and Ducati style number plate holder, a new style rear hugger which incorporates the chainguard is fitted for added protection for both chain and rear shock.
Finally we fit an Akrapovic Titanium exhaust, Pro-Mach/Ohlins Ducati-style steering damper kit and Pro-Mach multi adjustable footrest kit (all moving parts incorporate roller bearings and a choice of colours is available) Pro-Mach manufacture 50% of Superbike footrests and are probably the best in the world.
    22.8 KB · Visningar: 102
    20 KB · Visningar: 115
    6.8 KB · Visningar: 179
    4.4 KB · Visningar: 175
    5 KB · Visningar: 175
QB Aprilia MotoGP replica
Aprilia's RS3 is one of the best looking bikes in the MotoGP paddock and our Aprilia MotoGP replica was created to mirror those looks. The MotoGp replica fairing features the twin air intakes of the RS3 Cube whilst retaining the mille headlamp unit, at the rear the restyled seat unit has a LED rear light unit. A full Giannelli race system replaces the standard exhaust system, and rearset footrests and PFM six pot brake calipers complete the conversion.
-Aprilia MotoGP style fairing with twin air intakes retaining standard headlight
-Aprilia MotoGp style seat unit with LED rear light
-Carbon fibre front fender and chainguard
-Giannelli titanium twin exhaust system
-Robby Moto rearset footrests
-PFM six pot brake calipers
-Ohlins suspension
    25.4 KB · Visningar: 68
    28.1 KB · Visningar: 77
    7 KB · Visningar: 171
    6.6 KB · Visningar: 169
    7.2 KB · Visningar: 173
För att inte förglömma deras endurance-f4:a. Porr i kvadrat.
    119.7 KB · Visningar: 113
    80.2 KB · Visningar: 71
En sån och en sån och en sån tack!
Häftiga hojar onekligen! De har ju även MotoGp kåpor för Ducce som är rätt okej!
Kul med byggen överhuvudtaget. Eftersom jag har blivit såld på twinnar för tilfället så skulle jag välja Aprilian bland dessa.
Custom Bike Show den 6e juni.
Stor invigning på Sulas MC
Nyheter från Wunderlich
Harley-Davidson lanserar RIDE
KTM uppdaterar sin elhoj
