Lite M-1 teknikfrosseri.
Vilket jävla putsbögeri! Det svider i ögonen ju! Nej, det ska vara så skitigt att man inte kan skilja delarna från varann. (Obs! Ironi)
kajlyl skrev:
någon som har lite teknisk fakta? vikt, effekt o.s.v....
Håll till godo. Hur sanningsenligt det är vet jag inte men närmare kommer man nog inte då det är Yamahas egna siffror.
Engine: Liquid-cooled, in-line, 4-cylinder, 4-stroke with 20-valve DOHC
Displacement: 990cc
Ignition: Yamaha CDI with adjustable mapping - NGK spark plugs
Carburation: Fuel injection - Magneti Marelli
Lubrication system: Wet sump - Motul Oils
Data recording: 2D
Maximum Power: More than 210ps
Maximum speed: Over 320 km/h
Transmission Type: 6-speed cassette-type gearbox, with alternative gear ratios available
Primary drive: Gear
Clutch: Dry multi-plate slipper clutch
Final drive: Chain - DID
Frame type: Twin-spar aluminium frame
multi-adjustable steering geometry, wheelbase, ride height
with aluminium swingarm
Front Suspension: Fully-adjustable Öhlins inverted telescopic forks
Rear suspension: Braced aluminium swingarm
with single Öhlins shock and rising-rate linkage
Wheels: Marchesini 17.0 inch front, 16.5 inch rear, available in a variety of rim widths
Tyres: Michelin, 17.0 inch front, 16.5 inch rear
available as slick, intermediate, wet and hand-cut tyres
Front Brakes: Twin 320mm carbon discs
with radial mounted four-piston Brembo calipers
Rear Brake: Single 220mm ventilated stainless steel disc
with twin-piston Brembo caliper
Weight: 145kg, in accordance with FIM regulations
Fuel capacity: 24 litres
Specifications by YAMAHA
