Hur formatera en hårdisk i FAT32?
Thermal
:borrar olja.
12 Aug 2004
East Grinstead, UK
En gul Triple 06
Som sagt hur gör man det i Windows XP? En kollega har köpt en billig skitmediaspelare med en 500 gb hårddisk som han vill ha igång. Av nån anledning kräver den att formateras i FAT32 om man vill kunna spela upp på tv:n :mad:
När jag försöker formatera den i Windows XP kan jag av nån anledning bara välja NTFS, men när jag kollar hjälpen står det att man ska kunna välja just FAT32. Men inte på min, ska det vara så? :va
Hjälp mottages tacksamt.
C:\>format /?
Formats a disk for use with Windows XP.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/Q]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
/FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS).
/V:label Specifies the volume label.
/Q Performs a quick format.
/C NTFS only: Files created on the new volume will be compressed
by default.
/X Forces the volume to dismount first if necessary. All opened
handles to the volume would no longer be valid.
/A:size Overrides the default allocation unit size. Default settings
are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K,
(128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K,
Note that the FAT and FAT32 files systems impose the
following restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526
FAT32: 65526 < Number of clusters < 4177918
Format will immediately stop processing if it decides that
the above requirements cannot be met using the specified
cluster size.
NTFS compression is not supported for allocation unit sizes
above 4096.
/F:size Specifies the size of the floppy disk to format (1.44)
/T:tracks Specifies the number of tracks per disk side.
/N:sectors Specifies the number of sectors per track.
C:\>
Har du XP Home Edition eller vad den heter? Har för mig att Microsoft av någon outgrundlig anledning tog bort möjligheten att skapa FAT32 i den men om man redan har en sådan disk så kan den använda den.
Du får ta disken till någon som har fullversionen av XP (eller Linux). :D
Enhjuling: Det där verkade väl komplicerat,,
Neutral: Jag har XP Media Center Edition, men det är väl samma som fullversionen eller?
Prövar att ladda ner partition magic med upphetsande 5kb/sek,,, kanske det går att göra nåt med det programmet?
Leta upp en Win98 maskin och formatera en floppy för BOOT kopiera in Fdisk och Format på den. Bota din PC på floppyn kör FDISK och sen Format på din HD.
Du borde kunna köra fdisk från en Win98-cd om du har en.
Media Center är en bantad XP med media add-ons så den har nog inte allt
som en XP Corp eller Pro har.
Annars kan du ladda ner FDISK från nätet säkert... det är inte direkt stort. :)
Problemet är att diskhanteraren i Windows XP samt Vista inte tillåter dig att fomatera partitioner som är större än 32GB i filsystemet FAT32.
Eftersom du har en 500GB-hårddisk med endast en partition så visar Windows XP endast NTFS-formateringsalternativet.
Denna begränsning fanns inte i Windows 98 eller Millennium.
Lösning för att komma runt detta har nämnt tidigare i denna tråd. (Windows 98/Millennium-bootfloppy/CD eller programmet Partiton Magic för win XP).
Mer info om FAT32-begränsningar:
http://windowshelp.microsoft.com/Windows/sv-SE/Help/5dd16a76-7224-45ed-946a-72d5c6dc6e821053.mspx
Det är bara en beskrivning av syntaxet för funktionen Format.
Om du först öppnar kommandotolken genom att gå till "kör" och sedan skriva "cmd" så får du upp kommandotolket (dos-fönstret).
Om du där skriver "c:\format c: /FS:FAT32" bör det fungera.
För att förtydliga lite då:
"C:\format" är själva anropet till funktionen som formaterar diskar.
"c:" därefter betyder att du vill formatera C: disken.
"/FS:FAT32" till sist betyder att du vill formatera disken med FAT32.
Däremot påpekar Eldstorm viktiga saker som gör att det nog inte fungerar ändå. Men ville bara reda ut syntaxet lite åt dig och det kan vara värt att försöka.
Om du skriver "c:\format /?" får du en lista på alla funktioner som kan användas med "format". Det var helt enkelt den listan Enhjuling kopierat åt dig. Jag lyfte bara ut den information som verkade mest relevant :)
Som lite överkurs då:
Skriver du "c:\help" i kommandotolken får du en lista på alla kommandon som finns. Skriver du "c:\<kommandots namn> /?" så får du upp alla funktioner kopplade till det kommandot.
