Gruppköp Fiddy - Intressekoll
köra fiddy är faktiskt skitkul, jag råkade ha lite hög fart över ett hopp :yoparty :D
    55.6 KB · Visningar: 90
Kan du inte ta in denna gat lagliga version i stället?
Thumpstar Motard - The Thumpstar Motard is a road registered 120cc, 4 stroke pit bike, complete with log-book and all other necessary paperwork. Thinking of buying yourself a scooter to beat the traffic on the daily commute? Well think again! Introducing the new Thumpstar Motard, the ultimate congestion busting solution for urban warriors everywhere.
More than a mere commuting tool (though it is perfect for that too), with its incredible handling prowess and torquey 120cc 4-stroke engine, it's the ideal companion for blasting down back roads on a sunny day.
That 120cc 4-stroke engine is at the core of this bikes tremendous flexibility. Rather than having to rev the nuts off a little 2-stroke engine to get anywhere, the grunt of this motor allows nipping through traffic to be done without unnecessary drama. Then when things open out, wind open the throttle and enjoy clean, linear power right through the rev range.
Converted to a road going machine by the tech wizards at Gizmos, the Thumpstar Motard is based on the Thumpstar pro pit bike. On top of all of the features of the Thumpstar pro pit bike, the motard version is fitted with the following additional features, Super Motard Tyres, Stiffer Suspension, Front Headlight, Front & Rear Indicators, Brake Lights, Rear Mud Guard, Enduro Hand Guards, Light & Indicator Control Panel, Engine Cut Switch, Horn, Digital Speedmometer, Digital Rev Counter and Carbon Fibre Tax Disk Holder.
Complete with log-book the Thumpstar Motard is ready to ride on the road, completely legal and registered through the necessary authorities, it sure beats the pants off any scooters out there. Cheap insurance, cheap to run and looks that would kill, this bike is sure to be a massive hit!
Länk: http://www.gizmos-uk.com/Thumpstar%20Motard.html
Men inte från uk utan Kina men med rätt Papper från fabriken Tack. :tummenupp
Jag har fått ett kanonerbjudande på ett par fiddysar.
4500kr och kan hämtas omedelbart. Provkörning kan anordnas först.
Dom har följande utrustning
3) Speed: 80km/h
4) Range: 45km
5) Load capacity: 120kg
6) Volume of tank: 3.2L
7) Engine: 110cc, 4-stroke
8) Cool mode: air -cooled
9) Start up: kick
10) Battery: 6Ah/12V
11) Brake: front and rear hydraulic brake disk
12) Front tire: 2.5 x 10
13) Rear tire: 2.75 x 10
14) Transmission: 4 speed with manual clutch
15) Protection: skid plate
16) Max power: 8HP
17) Dimensions: 130 x 38 x 75cm
18) Push button start and stop
19) Stop next to clutch
20) There is a key fitted to the bike
21) Exhaust: big bore exhaust
22) Handlebars: high handlebars
23) Frame: powder-coated black (other colors available)
24) Fork tubes: powder coated black
25) Forks: high performance with reduced weight
Vem är intresserad? Vi måste köpa minst 5st.
1. Mr K
2. GSXR1100R är du fortfarande intresserad?
3. RogerR är du fortfarande intresserad?
4. Grodögat är du fortfarande intresserad?
5.
6.
7.
8.
9.
1. Mr K
3. Grodögat är du fortfarande intresserad?
4.
5.
1. Mr K
4.
5.
Jag har plöjt ner för mycket i RR hojen, jag hoppar av.
1. Mr K
2. Grodögat är du fortfarande intresserad?
3.
4.
5.
1. Mr K
2. Grodögat
3. Mr K #2
4. Mr K #3
5.
En till så blir det bra ..........
1. Mr K
2. Grodögat
3. Mr K #2
4. Mr K #3
5. Zxr_Green (kommer att få leva på vatten o grovsnus resten av månaden)
6. Zxr_Green´s Chef
1. Mr K
2. Grodögat
3. Mr K #2
4. Mr K #3
6. Zxr_Green´s Chef
7. Gyver (När, var, hur, testa/hämta??)
Vi ska kolla/testa i helsingborg på måndag kväll. Har du inte pengar förrän löning så får du ta med dig 1000kr i handpenning. Har du alla pengarna redan så kan du ta hojjen på plats. Ring mig på måndag 0705206481
