Från nätet. Inte klockren översättning men ni kan dra vissa slutsatser själva antar jag.
PLAN AX05:
Madness RD in key supermotard? (it would have to be amusing) Front chassis: Staple FZR 1000 with motivatings force reviews Marvic Circle in magnesium 17?x3,50 with 120/70 Discs ø320 with pliers 4 pistoncini (FZR) Slab staple supertenerè with handle-bar cross Bearings of steering to conical seams
Retrotreno: Forcellone of origin FZR 1000 with leveraggi and dismissals Shock-absorber FZR1000 EXUP with leveraggi modified for a greater excursion Marvic Circle in magnesium 17?x5,5 with 180/55 Disc ø260 former FZR Line moved chain all?esterno (by now is a defect)
Motor: Drainages? We will see!! Noises suppressor in Radiating aluminum self-made of Cagiva origin Myth System?potato electrical worker? reduced lessened indispensable
Chassis: Completely autocostruito with main beam in steel and lateral slabs in ergal the motor it turns out hung posteriorly on the attacks originates them, front I have constructed to an appropriate fixed stirrup to the bolts of the witness (a po? various from the AX01 for differences of chassis) Interasse 1370mm steering angle 25°
Auto body: All the aesthetic garment comes from one Yamaha 250 cross of the?92 As you can notice the Ax-05 is still in phase of construction, I hope to finish within aim anno?.per hour I can say to you that the greater problems will be the expansions and hiding all parts RD (tank oil, servomotore imp.elettrico) under the striminzita auto body (sull?AX01 c?era much place under the carene.)
ENDED in date 30/12/2002!!!
