Bromsvätska
AndersIvar
27 Apr 2005
GBG
GSX-R 1000
Halåsan,
Tänkte byte bromsvätska fram på min gamla ångbåt. I Clymer boken står det att man skall ha DOT 3. Min fråga är, kan man köra med DOT 4 istället? Vad är skillnaden? Vi har DOT 4 till bilarna på jobbet så jag kan spara 20öre på att ta det där istället...
Akn78 skrev:
Halåsan,
Det går alltid att gå upp i DOT klass förrutom att man inte häller i DOT5 silicone
bromsvätska som komprimeras mer än "vanlig" bromsvätska vilket inte är bra till mc för "handtaget" går i botten vid aktiv körning.
DOT: Acronym for "Department of Transportation" -- an American federal agency or "Department of Transport" -- a British agency
DOT 3: This brake fluid has a glycol base. It is clear or light amber in color. Its dry boiling point is 401° minimum and wet boiling point of 284° minimum. It will absorb 1 to 2 percent of water per year depending on climate and operating conditions. It is used in most domestic cars and light trucks in normal driving. It does not require cleaning the system and it can be mixed with DOT 4 and DOT 5.1 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
DOT 4: This brake fluid has a borate ester base. It is clear or light amber in color. Its dry boiling point is 446° minimum and wet boiling point of 311° minimum. It is used in many European cars; also for vehicles in high-altitude, towing, or high-speed braking situations, or ABS systems. It does not require cleaning the system and it can be mixed with DOT 3 without damage to the system. The problem with it is that it absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
DOT 5: This brake fluid generally has a silicone base. It is violet in color. Its dry boiling point is 500° minimum and has no wet boiling point in federal DOT 5 specifications. It is used in heavy brake applications, and good for weekend, antique, or collector cars that sit for long periods and are never driven far. It does not mix with DOT 3, DOT 4, or DOT 5.1. It will not absorb water and will not damage the paint on a vehicle. It is also compatible with most rubber formulations. The problem with it is that it may easily get air bubbles into the system that are nearly impossible to remove, giving poor pedal feel. It is unsuitable for racing due to compressibility under high temperatures. If as little as one drop of water enters the fluid, severe localized corrosion, freezing, or gassing may occur. This can happen because water is heavier and not mixable with silicone fluids. It is unsuitable for ABS.
DOT 5.1: This brake fluid has a borate ester base. It is clear or light amber in color. Its dry boiling point is 500° minimum and wet boiling point of 356° minimum. It is used in severe-duty vehicles such as fleets and delivery trucks, towing vehicles, and racecars. It can be mixed with DOT 3 or DOT 4 without damage to the system. It maintains higher boiling point than DOT 3 or DOT 4 fluids due to its higher borate ester content. It is excellent for severe duty applications. The problem with it is that it costs more than other fluids and there is limited availability. It also absorbs moisture out of the air and thereby reduces its boiling point. It can also damage the paint on a vehicle.
Det viktigaste är att hålla isär DOT 5 och DOT 5.1 annars kan det bli fel.
Shelby Turner, klar för GGN
Nya BMW S 1000 RR tar form
Sommarauktion hos Antiqueweb
