AI-genererade frågor
MickeZX7R
Posör
2 Jun 2015
Karlskrona
700 CL-X Sport, 500W Bafang
Först ut blev min fråga/rubrik: "how to tune a motorcycle engine".
AI svarade:
"Assuming you would like a paragraph on the steps of tuning a motorcycle engine:
Tuning a motorcycle engine is a process that is unique to each individual machine.
However, there are some general tips that can be followed in order to ensure that the engine is running as efficiently as possible.
The first step is to check the spark plugs and make sure that they are clean and in good condition.
Next, the air filter should be checked and replaced if necessary.
The carburetor also needs to be cleaned and adjusted in order to maintain the correct fuel to air ratio.
Finally, the ignition timing should be checked and adjusted if necessary.
By following these steps, the engine will be running at its best and will be less likely to experience problems."
Alltså utgår AI:n ifrån förgasare, annars var det väl inga direkta fel i rekommendationerna även om det var ganska tama förslag : )
"how to kiss a girl"
AI: "When it comes to kissing a girl, there are a few things you need to keep in mind.
First, make sure that you have good hygiene and that your breath smells nice. No one wants to kiss someone with bad breath!
Second, make sure you are in a good location. A dark, secluded place is usually best.
Third, make sure you are gentle and soft when you kiss her.
No one likes to be kissed too hard or too aggressively.
Finally, enjoy the moment and let your lips do the talking!
:oops:
:oops:
Nu kan du pröva på , lycka till gossen
CIAO ITALIEN!
Nu jobbar vi med Katalogen!
Provkörningsvecka, KTM 1390 Super Adventure S EVO!
Bike är på plats på sommarv...
Nortons comeback
Boxer, V3, V4, VR5 och 6-cyl
Teknik – nya mc-motor...
Gotland Ring Bike Week 2026
Motorsportsalongen i Örebro!
