Nytt Kinamärke - QJMotor
Wiseguy
Medlem nr.8 sen starten
"The first trio of bikes reaching Europe are the parallel twin naked SRK700 and SRK400, plus the retro-styled SRV550, which shares its chassis with Benelli’s Leoncino 500. This gains the larger 554cc engine that MV Agusta is set to use in their Qianjiang-made Lucky Explorer 5.5.
The SRK700 is the most intriguing model of the three, as it has no Benelli equivalent, and features a 698cc parallel twin that’s remarkably similar to the unit in CFMoto’s 700CL-X. With 72bhp, the Euro5-certified engine’s peak power exactly matches that of Yamaha’s MT-07, as does the claimed 49.4lb.ft of torque, although QJMotor claim to hit both peaks at lower RPM than Yamaha can manage.
With a full 15-litre tank of fuel, the SRK700 rolls in at 196kg and will come with a German RRP equivalent to £5900 – that’s £1300 less than an MT-07 and £700 less than a CFMoto 700CL-X Heritage.
Step down to the SRK400 and you have a clear rival to the Yamaha MT-03. Powered by a 400cc parallel twin it makes 41bhp – around half a bhp less than an MT-03 – but offers 5.5lb.ft more torque than the Yamaha at 37.3lb.ft and doesn’t need to rev as hard. Its weight penalty over the Japanese bike is more substantial at 18kg, for a total of 186kg wet.
Finally, there’s the SRV550. A 47hp A2 licence-friendly machine that shares much with the Benelli Leoncino 500 and gets an extra 54cc but no more power thanks to the A2 licence limit. At 206kg wet it’s the heaviest of the initial trio. Costing the equivalent of £5350 in Germany before on-the-road charges, it’s within £50 of the Leoncino 500’s RRP, too. "
SRK700
SRV550
  • Gilla
Reaktioner: TCE
Jag tror att det kommer att gå precis lika bra som för alla andra kina motorcyklar på marknaden!
Den här hade dock inte helful kalleankachopper design som många föregångare.
Jag köper glatt kinaskit när jag köper oviktiga saker, och det slutar aldrig att förvåna mig hur dåligt man kan göra saker som vore enkla att göra bra.
Men det här kan vara undantaget?
OM kineserna ska göra motorcyklar så bör de hålla sig till enkla bruksfordon, såna de åker med i u-länderna. 1-cylindriga småhojar på 125cc. Kanske en kinatillverkad SR250 kunde vara något..?
Tja, de har blivit bättre på att kopiera andras modeller iaf...
Den första hojen ser ju ut som ett amalgam av en ER6n och en Z650.
Den andra hojen ser bekant ut men kommer inte på vilken modell det liknar.
Försöker den inte likna Ducati Scrambler, eller?
FAst dens er ju inte ut att dela det chassit? Det är ju en annan ram, annan bakdämpareplacering och svingen ser annorlunda ut med...
Inte ens samma ord ju?
Rätt likt, namnet kommer liksom därifrån ;) Eller nja, tekniskt sett kommer det säkert ur latin ursprungligen... Men anledningen till att amalgam, i betydelsen tandläkarlegering, heter så är för att ordet betyder just blandning, och det används kanske inte jätteofta på det sättet i svenskan men utomlands är "amalgamation" ett mer vedertaget begrepp.
Nej det används sällan i svenskan och att googla ett annat ord gör det inte särskilt mycket mer legitimt
Jag försökte bara hjälpa dig att förstå genom att härleda betydelsen ifrån ett annat ord som jag tänkte att det är mer troligt att du hört i något sammanhang, så att förståelsen kanske blir lite mer intuitiv. Men vill man inte bättra på sin bildning så kan man ju skita i det och välja att tjura över att folk använder ord man inte förstår också, det är ju upp till var och en :)
Shelby Turner, klar för GGN
Nya BMW S 1000 RR tar form
Sommarauktion hos Antiqueweb
