GSX-R 1000 L7 202Hk
Triggerhappy
Måste man tvätta den?
25 Apr 2003
Kungsängen
Hojlös
Vi välkomnar Suzuki till 2010talet...
202Hk
Elektronik uppdaterad
Quickshifter
mm mmm
http://www.globalsuzuki.com/globalnews/2016/1004.html
Comprehensively enhanced for the first time in eight years, the sixth-generation of Suzuki’s flagship supersport bike GSX-R1000 and its advanced version GSX-R1000R have been evolved further by incorporating technologies earned in MotoGP. The features of GSX-R series, “Run. Turn. Stop.”, which are the fundamental design of harmonizing the engine and chassis, are thoroughly reviewed and balanced in high dimension.
Main features of the GSX-R1000 and GSX-R1000R
Engine
- Newly-developed 999.8cm3 in-line four-cylinder engine has adopted a new system called the Broad Power System, which incorporates technologies developed in MotoGP. The Broad Power System is a technology that strikes a balance between enhancing output in the high rpm range and low-to-mid speed range output. It is composed of four systems: 1. Intake VVT (variable valve timing); 2. Electronic throttle body; 3. Valve train system; and 4. Exhaust pressure tuning valve.
- Meets the new Euro4 emission standards (for European specification).
Chassis
- Newly-developed frame has reduced width for enhanced aerodynamics, and is 10% lighter with optimized rigidity.
- Improved cornering performance and manoeuvrability thru changing the engine’s cylinder angle and shortening the distance from the front axle to the swingarm pivot centreline.
- Completely redesigned cowling with smaller frontal projected area for large improvement in aerodynamics.
Equipment
- Brembo radial mount front brake calipers are matched with T-drive brake discs tuned for production models, which produce more efficient transfer of stopping power.
- ABS variant (ABS is standard equipment for GSX-R1000R) is equipped with Motion Track Brake System, which reduces rear-wheel lift during very hard braking by employing the IMU (Inertial Measurement Unit). Plus, the system equipped on the GSX-R1000R also optimizes front brake pressure when the front brake is applied, based on the leaning angle of the motorcycle to suppress reduction in front tire grip.
- Motion Track Traction Control System allows the rider to select 10 different levels of traction control intervention, depending upon road or racetrack conditions as well as personal preference and experience level.
- Systems such as Low RPM Assist, which raises engine rpm in starting and in low rpm range, and Suzuki Easy Start System, which enables the rider to just one-push the starter instead of press-holding it to start the engine, are adopted.
Main specification (for European specification)
- Maximum output: 148.6kW (202ps)/13,200rpm
- Maximum torque: 117.6Nm (12.0kgfm)/10,800rpm
- Vehicle weight: 200kg/202kg (ABS variant)/203kg (GSX-R1000R)
Main features of the GSX-R1000R
- Launch control system is adopted for the first time on Suzuki production models (excluding competition models). The system makes it easier to get a good start by helping it reduce the chance of a wheelie by automatically limiting engine rpm and optimizing torque delivery.
- Quick shift system is adopted for the first time on Suzuki motorcycles, which enables quicker and smoother shift changes.
- Standard equipment of racing-developed, high performance Show Balance Free Front Fork and Balance Free Rear Cushion Lite.
Mmh, har varit mycket intressant från intermot i år, ska bli riktigt kul att klämma lite på hojarna på mässan i vinter.
Visst brukar väl japanerna ange hk siffror på motorn och inte hjulet?
Då borde det bli +180hk på hjulet ungefärligen...
Kan bli intressant beroende på prissättning.
Såg nu att både Aprilia och Bmw gjorde det på sina med.
Rsv4 RF och S1000rr ska ha 201 resp 202hk på veven så då ligger sukkan riktigt bra till.
Akrapovic´s hemsida är ju ganska ok för att jämföra olika maskiners effekt... smidigt!
Alla är ju bromsade på mer eller mindre jämförbara grunder.
Alltså dessa jävla tunnor till avgassystem alla nya hojar har. Nästan så man kan tro dom har lierat sig med slipon-branschen och gör så fula som möjligt så alla måste byta.
Säkert en grym hoj i övrigt ????
Mycket kul som släppts idag där nere i från på mässan. Är väl nästan bara en ny cb1000r som är kvar nu
Skickat från min D6503 via Tapatalk
Eller... Avgaskrav och ljudkrav.
Och eftersom att alla ändå byter slipon det första de gör så är det en bortkastad utgift att lägga pengar på den delen.
De släppte även en hottare variant med R på slutet - GSX-R1000R.
No, that extra R in GSX-R1000R isn’t a typo – Suzuki is releasing two versions of its superbike at INTERMOT today, the 2017 Suzuki GSX-R1000R being the higher spec model for track enthusiasts.
Available later in mid-2017, the Suzuki GSX-R1000R takes the already robust package that is the Suzuki GSX-R1000, and adds to it an up-and-down quickshifter, launch control, and cornering ABS feature set.
The suspension has also been upgraded, with the 2017 Suzuki GSX-R1000R getting the very noticeable Showa Balance Free forks (note the gas cartridge on the fork bottom), and the Showa Balance Free Rear Cushion rear shock, which is an interesting piece of kit, since Showa says the design does away with the need for separate high-speed and low-speed compression adjustment.
The last item of difference, besides the price of course, is that the 2017 Suzuki GSX-R1000R includes a lighter triple tree top clamp.
While both the GSX-R1000 and GSXR-1000R benefit from Suzuki’s all-new inline-four engine with variable valve timing, it is interesting to note that they do not share the same electronics package.
Screenshot Nya BMW F 450...
Nya MV Agusta Brutale 800
Nu startar mässan i Milano
EU:s fartgräns för MC stoppad
Påvens BMW R18 utauktionerad
GGN 2025, värsta hittills !
Bildsvep – GGN 2025
