Nix, jorden går inte under; NASA har svaren på dina foliehattsfrågor
Bettskena
It's good to be me!
7 Aug 2006
Gixxer 750 K8
Question (Q): Are there any threats to the Earth in 2012? Many Internet websites say the world will end in December 2012.
Answer (A):The world will not end in 2012. Our planet has been getting along just fine for more than 4 billion years, and credible scientists worldwide know of no threat associated with 2012.
http://www.nasa.gov/topics/earth/features/2012.html#end
för de som fortfarande tror och är övertygade om det motsatta; varsågoda att samlas under denna intergalaktiska forum och beundra varandra--------------------------------------------->http://www.peopleofwalmart.com/
Bara å planera sin ledighet & domedag av denna kalender!
At 01:46:40 UTC on 9 September 2001, the Unix billennium (Unix time number 1,000,000,000) was celebrated.[5] Some programs which stored timestamps using a text representation encountered sorting errors, as in a text sort times after the turnover, starting with a "1" digit, erroneously sorted before earlier times starting with a "9" digit. Affected programs included the popular usenet reader KNode and e-mail client KMail, part of the KDE desktop environment. Such bugs were generally cosmetic in nature and quickly fixed once problems became apparent. The problem also affected many 'Filtrix' document-format filters provided with Linux versions of WordPerfect; a patch was created by the user community to solve this problem, since Corel no longer sold or supported that version of the program. The name is a portmanteau of "billion" and "millennium". [6][7]
At 01:58:31 UTC on 18 March 2005, the Unix time number reached 1,111,111,111.
At 23:31:30 UTC on 13 February 2009, at exactly 23:31:30 (UTC) the decimal representation of Unix time reached 1,234,567,890 seconds.[8] In some parts of the world, this day fell on Friday the 13th in the Gregorian calendar. (14 February for locations from France east to the International Date Line.) Google celebrated this with a Google doodle.[9] Parties and other celebrations were held around the world, among various technical subcultures, to celebrate the 1,234,567,890th second.[10][11]
26 January 2011 was the 15,000th day of Unix time; this was celebrated in Bloomington, Indiana.[12][13][14]
At 03:33:20 UTC on 18 May 2033, the Unix time will reach 2,000,000,000 seconds, the second billennium.
At 06:28:16 UTC on 7 Feb 2036, Network Time Protocol will loop over to the next epoch, as the 32-bit time stamp value used in NTP will overflow.
At 03:14:08 UTC on 19 January 2038, 32-bit versions of the Unix time stamp will cease to work, as it will overflow the largest value that can be held in a signed 32-bit number. Before this moment software using 32-bit time stamps will need to either adopt a new convention for time stamps or be migrated to 64-bit systems,[15] and file formats using 32-bit time stamps will need to be changed to support larger time stamps or a different epoch.
At 06:28:15 UTC on Sun, 7 February 2106, the Unix time will reach 0xFFFFFFFF or 4,294,967,295 seconds which, for systems that hold the time on 32 bit unsigned numbers, is the maximum attainable. For these systems, the next second will incorrectly be Thursday, 1 January 1970 at 0:00:00.
At 17:46:40 UTC on Sat, 20 November 2286, the Unix time will reach 10,000,000,000 seconds, the tenth billennium.
At 15:30:08 UTC on Sun, 4 December 292,277,026,596[16][17] 64-bit versions of the Unix time stamp will cease to work, as it will overflow the largest value that can be held in a signed 64-bit number. This is considerably longer than the time it will take the Sun to expand to a red giant and swallow the earth.
Antar att du menar att 32bitars inten tar slut då?
http://en.wikipedia.org/wiki/Unix_time#Notable_events_in_Unix_time
Det är i princip redan fixat. Det lär nog bara vara några urgamla bankmainframes som lägger sig på sidan och sprätter till några gånger.
Men tänk om de verkligen går under? Då får olyckskorparna vatten på sin kvarn. Jävvlar va skadeglada de ska va. "Ha! Vad sa jag? Sa jag in...........KABOM"
121212 är snarare ett datum att lägga till minnet. Dagen då Federal Reserve informerar om kommande QE4.
Saken är den att vi redan gått under och lever nu i en spökvärld :gnissla :gnissla :gnissla Så de hade rätt men det märks inte :gnissla
KTM uppdaterar sin elhoj
Screenshot I samband med...
