iPhone-tråden
Varför inte konvertera en soldriven Sunnan IKEA-lampa till en iPhone laddare?
http://lifehacker.com/5856674/
http://www.ikea.com/se/sv/catalog/products/90154371/
Apple funderar på att släppa Siri till äldre enheter oxå.
http://macdailynews.com/2011/11/05/...or-iphone-4-seeds-internal-build-for-testing/
Apple may release Siri for iPhone 4; seeds internal build for testing
Saturday, November 5, 2011 · 5:29 pm · 21 Comments
“If you were disappointed by the fact that Apple has made Siri an exclusive iPhone 4S feature, there is still some hope for you,” Alexander Vaughn reports for AppAdvice. “We’re being told that there is still a chance that Apple will be bringing the feature to older iDevices such as the iPhone 4.”
“Indeed, as revealed by the folks at Jailbreaknation, Apple is still considering releasing Siri on the iPhone 4 and went as far as installing a special built of iOS 5 that includes Siri on a number of Apple employee’s iPhone 4 recently to test it out for a few days,” Vaughn reports. “The news, comes from a source of Jailbreaknation close to Apple, which they were kind enough to let us verify, and it does appear to be legitimate.”
Vaughn reports, “A second source also confirmed to us that the test went really well as far as performance is concerned. Unfortunately, the microphone of the iPhone 4 is not as good as the 4S one, and this might be holding Siri back if they can’t overcome this with software.”
Read more in the full article here.
http://appadvice.com/appnn/2011/11/apple-siri-4
[Thanks to MacDailyNews Reader "Don" for the heads up.]
Skumt knas på min 4:a, ibland när det ringer och jag ska "slide to answer" så studsar den lille jynnaren tillbaka, ibland 10-15 gånger innan den till slut öppnar samtalet.
Har en Otterbox defender case och den har ju en extra plastfilm på framsidan, kan det påverka, tro?
edit: när jag tänker efter så har den blivit lite jobbig efter iOS 5, appar kraschar Hacke Hackspett i lurarna när man lyssnar på musik, osv.
samma sak på min..sliden vill ibland inte gå hela vägen.
Låter som ytterligare en bugg utöver batteriproblemet.
På min 3GS har jag dock inte märkt av något av detta.
När inte sliden vill så bara tryck på sleep/wake o sen går den igen. Har själv det så ibland, har dock varit så långt innan ios5 och även på 3gs när man hade en sådan.
Jag brukar byta mitt grepp om mobilen när det händer, har fått för mig att det handlat om att den andra handen nuddar eller råkar dutta emot skärmen och därmed krånglar det, men kanske har fel om det!? :)
jag har varit i kontakt med telenor och fått samma svar. jag misstänker nåt liknande, har mer problem hemma än på jobbet. känns som själva problemet är att telefonen inte klarar att hitta täckningen igen om den en gång tappat den.
edit: skönt att det inte har pratats något om att dom flyttat ner knapparna på 4s. Fick hem mina ebay skal nu och dom sitter ju skit pga det. lästa om det nånstans häromdagen men va som sagt redan beställt. tänk på det innan ni lägger multum på fräna skal.
Inte knapparna, knappen till ljud av/på är flyttad inget annat. Synd att du inte gogglade innan, finns massa forumdiskutioner om det..
http://www.idg.se/2.1085/1.414470/har-ar-niclas-stulna-ipad
Bra program, men tydligen har man ingen nytta av det i Sverige..
Men seriöst nu, läs innan du börjar "tycka" på samma sätt som Aftonbladet gör... dvs inte kolla vad det beror på innan man börjar yttra sig.
Anledningen till att det inte funkar i just det fallet är att "find my iPhone"appen pinpointar den till ett lägenhetskomplex och det går inte att avgöra vilken av lägenheterna det gäller... skulle du själv tycka att det vore ok om polisen knatade in i ditt hem för att de kanske misstänker att det finns en stulen iPad där? :va
Haha, vissa hugger direkt när det skrivs något negativt, spelar ingen roll om det är sanning, det måste huggas. Humor!
Klev in på teliabutiken i stan och trodde jag skulle få med mig en 4S 32:a med mig hem. Men nä den måste vi beställa...:näsblod och sen tar det 3-5 arbetsdagar innan den funkar eftersom jag vill byta Op.
Det är ju fan helt ryskt...
Här kom det oväntat ett sms om att där låg ett paket på posten o vänta..
Trilla in en 32gb´s 4s några veckor snabbare än jag hade väntat mig.
Alltid redo för regn
