Mr K
I win, you loose!
PRIS ENDAST 345kr inkl frakt
They work with most of the beacons in the market including XT,AIM.
Important Features:
Only cost 1/20 of a XT Mini;
Big Readout;
Long Battery Life;
High Accuracy;
The transmitter:
The transmitter has laser pointer and the signal transmitter to build the “Signal wall”;
It is powered by 2 x AA batteries; Lasting 5 hours continuously;
It is proposed to turn off the transmitter during idle to save power;
Note:
Batteries need to be replaced after 5 hours of use to avoid weak signals;
Take the batteries out of the box during long idle;
It is forbidden to point the laser to eyes, keep the product away from children.
O The time tolerance of this device is 0.0035 seconds for each lap; (CPU)
O This device is designed for track day and trainers; It has all basic function that is required for track day.
O Product size: 60mm x 40mm x 12mm
O Max Lap time and Max total time: 99 minutes 59 seconds;
O Max lap to record: 64 laps;
O When there is continuous signal, only the first signal will be counted;
O The signal receiver is built in the timer, make sure the receiver is exposed to the “signal wall” created by the transmitter;
O The laser pointer helps to build the signal wall; Make the “wall” as vertical to the track as possible;
O When you are not able to expose the signal receiver to the “signal wall”, try to turn the “wall” to different angles;
Intresselista
1. Mr K
2. Ninja_Assassin
3.
4.
5.
6.
7.
8.
9.
osv
Important Features:
Big Readout;
Long Battery Life;
High Accuracy;
The transmitter:
Note:
Intresselista
1. Mr K
2. Ninja_Assassin
3.
4.
5.
6.
7.
8.
9.
osv
