Blanco
Glad påsk!
Det är tydligen rätt så kallt där, inte bra för överlevande som är fast. Men samtidigt så hindrar det förruttnelse som var ett stort problem vid tsunamin 2004
"The nuclear reactor is surrounded by a steel reactor container, which is then surrounded by a concrete building," Chief Cabinet Secretary Yukio Edano said.
"The concrete building collapsed. We found out that the reactor container inside didn't explode."
Japan earlier in the day warned of a meltdown at the reactor at the plant, damaged when a massive earthquake and tsunami struck the northeast coast, but said the risk of radiation contamination was small.
"We've confirmed that the reactor container was not damaged. The explosion didn't occur inside the reactor container. As such there was no large amount of radiation leakage outside," he said.
"At this point, there has been no major change to the level of radiation leakage outside (from before and after the explosion), so we'd like everyone to respond calmly," Edano said.
"We've decided to fill the reactor container with sea water. Trade minister Kaieda has instructed us to do so. By doing this, we will use boric acid to prevent criticality."
Edano said it would take about five to 10 hours to fill the reactor core with sea water and around 10 days to complete the process.
Edano said due to the falling level of cooling water, hydrogen was generated and that leaked to the space between the building and the container and the explosion happened when the hydrogen mixed with oxygen there.
Nyhetsbyrån Reuters sänder från Japan
http://svtplay.se/v/2354929
edit:kan tro de blandat ihop det hela med en stream från mellanöstern![]()
Det där är Lybiska ambasaden i Tokyo...
En av mina bästa vänner ligger och lossar olja vid ett raff utanför Sendaiar, de har satelituppkoppling ombord så även om all kommunikation i land är väck lider inte de av det, men inte ett ljud från honom. Det ser inte så ljust ut tyvärr.![]()
FAAN, jag ska ju bada varma källor, klättra Fuji, dyka på Ishigaki och hinna klä ut mig till Geisha!!! Med tanke på våra resplaner får man hoppas att "the big one" dröjer minst 1.5mån...FAAN, jag ska ju bada varma källor, klättra Fuji, dyka på Ishigaki och hinna klä ut mig till Geisha!!!
Att en mört fastnar i kylvatteninloppet?
Det är ju jävligt konstigt att man i ett land som bokstavligt talat skakar sönder med jämna mellanrum törs satsa på och bygga nya kärnkraftverk, medans man i sverige är livrädda för riskerna.
Det fungerar ju uppenbarligen i Japan under värsta tänkbara förhållanden, vad är det värsta som kan hända här?
Ingen härdsmälta har bekräftats än och bara mindre, kontrollerade utsläpp av tryck har gjorts för att avlasta reaktorinneslutningen. Jag vill se siffror från officiellt håll på eventuella strålskador på personal innan jag ropar på vargen. Kontrollrummet är som regel försett med nödventilation så att de som kör verket ska kunna sköta sitt jobb.
Det värsta som kan hända är väl att elpriserna går ner när tillgången på el blir tillräcklig så vinsterna blir lägre för bolagen![]()
