Guinness
Elffors
Tibnor är min speedshop...
21 Aug 2008
hemma
, Redskapsmotoriserad herrcykel, o en kompressormatad gjutjärnsräser!
Är det nån som har koll på hur man får till den rätta skumkronan när man häller upp en guinness från flaska till sejdel?:va
Jag brukar undvika mellanhänder så mycket det går, med andra ord, i detta fallet, köra från flaska till hals/mage direkt :)
http://www.ehow.com/how_5482893_pour-perfect-guinness.html
For best results take your pint glass - run it under water (on the outside) to wet it down and put it in the freezer for 10 minutes. If you are European skip this step, we are lucky to get you to drink a cold beer let alone one out of a frosted mug.
Step 2
Get your can (or bottle) of Guinness from the fridge - 44ºF (7ºC) is the perfect temp. But no need to measure the temperature, I'm sure your fridge is set cold enough.
Step 3
Now 10 minutes has gone by - take your freshly frosted pint glass out of the freezer.
Step 4
Both the can an bottle can be handled the same way. OPEN the can/bottle. The magical widget inside causes the nitrogen/carbon mixture to release into the beer. Move on to Step 5 quickly as often your beer will overflow.
Step 5
In one smooth motion tilt the can/bottle into the glass. DO NOT tilt the beer glass. That's the magic of the Guinness head. One smooth pour. Often times not quite all the beer will fit into the glass. That's okay. It is however the only time you can drink Guinness straight from the can/bottle. I mean come on, we aren't Neanderthals here!
Step 6
Allow the nitrogen to settle out of the beer for 1 to 1/2 minutes. Guinness is now perfect.
Step 2
Step 3
Step 4
Step 5
Step 6
UUUU...låt mig gissa att nån jävla amerikan skrivit dedär...
Säkert.... Har svårt att en europé skulle "ni:a" andra europeer.
Däremot håller jag med honom om ofoget att dricka okyld öl. Öl skall serveras kall eller iaf kyld. Att dricka ljummen öl är inte tecken på god smak.
Jag orkade inte ens läsa igenom ordentligt..
Dessutom finns det annat än européer o amerikaner :D
Guiness ska inte drickas sådäringa kyld...
1) Flask-Guinness ger inte en skumkrona värd namnet. Den drickes med fördel direkt ur flaskan, möjligen sval om man känner för det men definitivt inte kall. Kall smakar den inget och man kan lika gärna dricka Budweiser, vilket förmodligen är vad amerikanen som skrivit det som postades ovanför är ute efter.
2) Ur burk, he bar å häll! Ölen reder ut det där själv. :tummenupp
3) Ni är ena jävla svin som pratar om sånt här när bolaget är helt och definitivt stängt ända till på måndag och jag inte har något som ens liknar Guinness hemma! :kulspruta :död
Använder Guinness de burkarna som jag har för mig just de tog fram där öl och kolsyra förvaras separat och blandas efter öppnandet?
Någon som vet vad jag svamlar om?
Henrik
Henrik
japp, det ligger en plastgrunka i burkarna som ska fixa skumkronan automagiskt. den ska nog innehålla en gas om jag inte misminner mig...
Ny fråga, varför går det att få den täta skumkronan på guinness men inte på lageröl? Skulle det även gå på porter?
Nu får jag ta mig en ny guinness efter ett mellanspel med en sketen norrland..
Fan lets dricka o bli fulla istället för att fundera på sånt skit..
Nope.. Ingen o supa med. Myskväll med tjejen fast hon fastnade i hästhoppning så nu sitter man här o fin tar lite bara.
...Ähh det blir ju ändå inget så man kan ju lika gärna hälla upp en stadig islay!
Putäll på rej,här var det ö-fjanteriet som tog intresset från mig,inte så svårt kanske då man inte är sådär jätteintressant kanske men ändå...
Henrik
Jag har svårt att tänka mig att ett frostat glas lyckas kyla ner en halvliter öl såpass att den kan anses "kall"...
Step 2
Läsförståelseproblem? Eller kanske heter det skrivförståelse i det här fallet... :tungan
Åfan, så noga läste jag faktiskt inte. Hemmablind som jag var fick jag för mig att det var glaset det handlade om som de kylde ner
Fy fan, amerikaner har samma känsla för smak som dee_cati och hans djälva kylda whiskey med ännu mer kyld cola och superkyld is....
