R6 - r46
PeeWee's fina länk leder oss bl.a. till...
R46 FEATURES AND BENEFITS
• Engine upgrades in the form of 40mm throttle bodies, revised fuel injection and ignition mapping, and new intake funnels result in a horsepower increase at the same rpm as before with more power across the board.
• New, fully adjustable inverted fork with 41mm tubes further reinforces R6’s main strength: precise handling. New, cast top triple clamp and forged lower clamp also increase rigidity, and work with revised handlebar positioning.
• To complement the new fork, the rear section of the Deltabox III main frame was revised internally to work with revised swingarm linkage and mounts for improved handling.
• Lighter, 310mm front brake discs replace 298mm units. New radial-mount four-piston calipers and radial master cylinder provide greater braking power and feel.
• 120/70-ZR17 front tyre replaces previous 120/60-ZR17 for improved handling.
• Twin, ring-type radiator fans are now used to ensure optimal engine cooling.
• Revised headlight lens and revised under-cowl for even better style.
• New Rossi inspired colour scheme.
Tänk efter en gång extra om du verkligen tycker den är snygg åtminstone. Själv tycker jag att den är ganska smaklös och kan tänka mig att de vanliga färgsättningarna är betydligt mer lättsålda.
Screenshot I kommande nu...
Ducati DesertX 2026
KTM firar 100 år av 6DAYS
