Über för er som brukar hjälpa vänner och bekanta med deras datorer istället för att sitta en heldag och installera så skall det gå på under timmen
PatchMate can install in as little as 5 minutes depending on system configuration. Installing patches even via a high-speed internet connection can take hours.
Jävligt slö download men det kan det vara värt när man väl har det på skiva sen.
Edit:
Readmefilen från downloaden README FILE - Patching Program CD Version 4.0 - 04/23/2009
Original release date 05/14/2002
Written by Dirk Fullerton
Email: techsupport@patchmate.net
Burn the contents of patchmatexp.zip file to CD and insert CD into target system.
Program should auto load. If not double-click on patch.exe.
Donations are welcome to continue support for this product and to keep the
website up and running. Intentions are to update the product every month.
Check back each month for the latest version. Attempts will be made to make
ISO images for easy burning to CD.
Thank you.
If you find any patches that remain to be patched after a base installation of
Windows XP please email me and I'll see what I can do for the next monthly
release. Please do the same for any bugs encountered.
Note: This program is for OS patches (Windows XP Home, Windows XP Pro SP1, SP2 and SP3 and IE patches only).
If other applications are present i.e. Microsoft Office, then
you must patch for them in another manner.
There is no warranty with this product. Use at your own risk
Note: OS Patches are up-to-date as of 04/23/2009. If there
have been additional patches released since this date,
then it is recommended that you download those patches
and test them on non-production network systems before patching
the production environment.
Note: Each OS has a base install of Internet Explorer. The
IE patches used for each OS are based on the initial Internet Explorer
version that came with the OS. If you have upgraded IE to a newer
version, then you will need to patch for it seperately.
Best effort has been made to ensure that all patches are applied to a base
system with no additional applications installed.
As always verify that your system is completely secure by using Windows Update
or other third party patching tools, Anti-Virus, Firewall, Anti-Spyware, etc...
Some files used in this program were written by:
Windows Admin Script Tools
(C) 2001-2003 by Bill Stewart (bstewart@iname.com)
Då tipsar jag om NLite som har just funktionerna för att slipstreama en installations-CD. Dvs du gör en customskiva med SP3 förinstallerat, alla drivrutiner för just din burk etc. Går även att baka in hotfixar, patchar och installationsprogram för i stort sett allt.
Jag har en installations-DVD med alla drivare för alla datorerna här hemma, skitsmutt att slippa hålla reda på gamla CD-skivor med drivare, leta sig blå på nätet efter dom osv.
Ytterligare en fördel med DVD är ju att man får in många fler program, ex office, photoshop osv. En hel basicuppsättning på en skiva.
