Bilder på gatversionen av BMW´s S1000
amullo
Italiensk Allroad
Solna, Stockholm
MTS1200s
Nu har det dykt upp bilder på den på BMW USA´s sida.
http://www.bmwmotorcycles.com/us/en/individual/news/index.html?id=145
Ful som stryk.:brinnerup
Spec:
Engine & Drivetrain
* 999 cc
* Bore/Stroke (mm) – 80.0/49.7
* 193 hp @ 13,000 rpm
* 83 lb/ft @ 9,750 rpm
* Compression – 13.0:1
* 48mm throttle bodies
* 14,200 rpm redline
* Valves operated by single cam follower
* 6 speed gearbox
* Slipper clutch
* Multi disc wet clutch
* Chain final drive
Suspension
* 46mm USD forks
* Adjustable preload, rebound, and high and low speed compression
* Single Shock with linkage
* Adjustable preload, rebound, and compression
* Pressure cast (forged) aluminum wheels
* 3.5 x 17 front
* 6.0 x 17 rear
* Dual 320mm floating rotors in front
* Radial mounted 4 piston Brembo calipers
* Single fixed 220mm rear rotor
* Single piston floating rear caliper
Special features
* 1st time available Race ABS & Dynamic Traction Control (DTC)
* E-gas (ride by wire) that works with Race ABS & DTC
* Four Settings:
* Rain
* Sport
* Race
* Slick
* Aluminum gas tank
* Built in laptimer
* Optional Gear Shift Assistant
* Variable intake runners
* Asymmetrical headlights derived directly from endurance racing
* Dry weight of 404 lb. 450lb wet with full tank, 455.3 wet with full tank and ABS.
* Available colors are Acid Green Metallic, Mineral Silver Metallic, Thunder Gray Metallic, and BMW Motorrad Motorsport colors.
* Black frame with all colors
* Mineral Silver and Thunder Grey come with Ostra Gray swingarm and wheels
* Acid Green and Motorsport come with a silver swingarm and gloss black wheels
Den är lika "ful" som vilken annan literhoj som helst. Fast framlyset ser lite kraschkåpe "besiktningsedisschön" ut.
Jag skulle kunna åka på den utan att skämmas!
Det är ju f*n galet hur mycket som de designmässigt snott från andra hojar.. Toppkåpan känns igen framifrån va?
Fattar dock inte varför de inte skickat in blinkers i backspeglarna.
