Humortråden, bidra med dina sjukaste, bästa och/eller tråkigaste skämt! OBS: låg nivå
En man kom in på ett café med en mus under armen. Han beställde en öl till sig själv och tio pannbiffar till musen…
-Vad är det för en märklig mus som kan äta tio pannbiffar?! undrade värden.
-Jo, det var så att jag räddade en liten fe och fick tre önskningar. Jag önskade mig god hälsa och mycket pengar, men den sista önskningen - en omättlig mus - missförstod ju den där lilla jävla cepefen totalt!
Det var en blondin i en cab som stannade brevid en lastbil vid ett trafikljus, blondinen hoppade ur och sprang till lastbilen, slet upp dörren och sa på Stockholmska:
Hej, jag heter Linda, jag tänkte bara säga att din last håller på att rinna ut!
Då lutade sig lastbilschauffören ut genom dörren och sa på norrländska:
Hej, jaa het' Benny, å hä' jaa som kö' saltbilen!
A guy walked into a bar with his pet monkey and ordered a drink. While he was drinking, the monkey jumped all around the place It grabbed some olives off the bar and ate them, then grabbed some sliced limes and ate them.
It jumped onto the pool table, took one of the billiard balls, stuck it in his mouth, and to everyone's amazement, somehow swallowed it whole.
The bartender screamed at the guy, "Did you see what your monkey just did?"
The guy said, "No, what?"
"He just ate a billiard ball off my pool table... whole!"
"Yeah, that doesn't surprise me," replied the guy, "he eats everything in sight. Sorry, I'll pay for the cue ball and stuff." He finished his drink, paid his bar bill and paid for the stuff the monkey ate and walked out.
Two weeks later he came into the bar again along with his monkey. He ordered a drink and the monkey started running around the bar as before.
While the man was finishing his drink, the monkey found a cherry on the bar. He grabbed it, stuck it up his rear, then pulled it out and ate it.
Then it found a peanut.. This, too, he stuck up his rear, pulled it out and ate it.
The bartender was disgusted "Did you see what your monkey did now?" he asked.
"No, what?" replied the guy.
"Well, he stuck a cherry up his butt, pulled it out and ate it. The same with a peanut!"
"Yeah, that doesn't surprise me. " said the guy. "He still eats everything in sight, but ever since he had to pass that cue ball, he measures everything first."
En sida med en del rikktiga kanonhistorier är
http://www.ukgser.com/forums/forumdisplay.php?f=39
Men jag vill varna känsliga personer, det är ett engelskt BMW-forum ni besöker!
Jag tar inte ansvar för att ni känner er tvingade att byta bort div. Österrikiskt, Italienskt och Japanskt skrot mot en BMW när ni besökt sidan!
Ye be warned:yoparty
Det är en uppsats av en (okänd) mellanstadieelev.
Historian om kon
Kon är ett husdjur... Men den finns också utanför huset. Och den lever ofta på landet, men den kommer också in til staden, men bara när den skal dö.
Men det bestämmer den inte själv.
Kon har sju sidor... Den översta sidan - Den nedersta sidan - Denfrämre sidan - Den bakre sidan - Den ena sidan - Den andra sidan- Och den invändiga sidan.
På den främsta sidan sitter huvudet... Och det är för att hornen skall Ha något att sitta fast på. Hornen är av horn och dom är bara till prydnad.
Dom kan inte röra på sig, men det kan öronen. Dom sitter på sidan av hornen.
Kon har två hål framme i huvudet. Dom kallas ko-ögon. Kons mun kallas mule.
Det är nog för att den säger mu.
På den bakersta sidan sitter svansen... Den använder den för att jaga Bort flugor med, så att dom inte ramlar ned i mjölken och drunknar.
På den översta sidan - Och den ena sidan - Och den andra sidan, är det Bara hår... Det heter ko-hår och har alltid samma färg som kon.
Färgen på kon heter kulör.
Den nedersta sidan är den viktigaste för där hänger mjölken. Och när mjölkerskan öppnar kranarna så rinner mjölken ut. När det åskar så Blir mjölken sur, men hur den blir det har jag inte lärt mig ännu. Kon har Fyra fötter. Dom heter kofötter. Dom kan också användas till att dra ut Spikar med.
Kon äter inte så mycket, men när den gör det äter den alltid två gånger. Dom feta korna ger helmjölk. När kon är dålig å magen ger den ost. I osten är det hål.Men hur den gör hålen har jag inte heller lärt mig ännu.
Kon har bra luktsinne. Vi kan känna lukten av den på långt håll. Kons valpar heter kalvar. Kalvens pappa heter tjur, och det gör kons man också.
Tjuren ger inte mjölk och är därför inte ett däggdjur.
Den som kommer och hämtar kon när den blir gammal heter kofångare. Den sitter ofta framme på bilar. Så blir kon slaktad, man häller mjölken i paket som vi kan köpa i affären. Kons fyra fötter skickas till snickaren. Det kallas återanvändning.
Som man kan se är kon ett nyttigt djur. Och därför gillar jag kon väldigt
mycket.
Lärarens kommentar: Jag har aldrig läst något liknande!
Den sista där var nog nåt av det sjukaste jag läst på länge!! Haha:D
Det var en gång... o den var sandad!
/ Tack för mig
Här kommer en riktigt långsökt en:tummenupp
Vad sa det mellan systembolagets chef och hans fru när dem träffades?
Det sa "kluck".
Vad sa det mellan systembolagets VD och hennes man när dem träffades?
Det sa "schlafs"
Varför lyssnar inte män...
Fru Johanssons diskmaskin gick sönder och hon tog kontakt med en
servicefirma, som lovade skicka en tekniker nästa förmiddag.
Fru Johansson hade avtalat ett möte samma förmiddag och instruerade därför teknikern:
'Nyckeln ligger under dörrmattan. Laga diskmaskinen och lägg fakturan på bordet.
Ni behöver inte vara rädd för hunden, han kommer inte att röra er.
Men tala absolut inte med papegojan!'
När teknikern anlände dagen efter, fann han nyckeln under
dörrmattan, öppnade dörren och stod öga mot öga med den största och mest
skräckinjagande hund han någonsin hade sett (Lukas). Hunden var dock
genomsnäll och tittade lugnt på, medan teknikern lagade diskmaskinen.
Papegojan däremot kastade nötter på honom, skrek, skällde och överöste
honom med obsceniteter. Till slut kunde teknikern inte bärga sig längre och
röt åt papegojan:
'Håll käften, din fula, jävla kråka!'
Då svarade papegojan: 'Hugg, Lukas! '
Varför kan män aldrig lyssna på vad kvinnor säger?
Det var en tjej som ringde och skulle beställa eldningsolja till sitt hus.
Till den som tog emot beställningen sade hon:
Skicka en med lång slang för jag har hålet så långt upp häcken.
Hej, svarar en liten flickas röst i telefonen.
Hej vännen, det är pappa. Är mamma i närheten? säger Gunnar.
Nej, pappa. Hon är uppe i sovrummet med farbror Bosse.
Efter en kort paus säger Gunnar:
Men du har ingen farbror Bosse, vännen!
Jo det har jag, och han är uppe i sovrummet med mamma!
Okej då. Jag vill att du gör en sak åt mig. Lägg ned luren, spring uppför trappan, knacka på dörren och ropa åt mamma och farbror Bosse att min bil precis körde upp på garageuppfarten.
Okej pappa!
Några minuter senare kommer den lilla flickan tillbaka till telefonen.
Jag gjorde som du sa pappa.
Och vad hände då?
Mamma hoppade upp ur sängen utan några kläder och sprang omkring och skrek hysteriskt. Sedan snubblade hon på mattan och föll nedför trappan. Nu ligger hon bara där och hennes nacke har vridit sig konstigt.
Åh herregud! Men farbror Bosse då?
Han sprang också upp ur sängen utan några kläder. Han verkade jätterädd och hoppade ut genom fönstret och ned i swimmingpoolen. Men han måste ha glömt att du tömde den på vatten för att rengöra den. Han slog i botten och ligger där utan att röra sej.
Efter en lång paus säger Gunnar:
Swimmingpool? Ursäkta men då har jag ringt fel nummer.
What's Belgium famous for?
Chocolates and child abuse.
They only invented the chocolate to get to the children...
:näsblod
Den nygifte svenske mannen till sin nya fru;
-"Du måste ha det helt klart för dig, på lördagar ska jag på fotbollsmatcher, fredagar och onsdagar ska jag på puben med grabbarna, och tisdagar spelar jag golf".
-"Ja, ja".. svarade hon.
-"Men du ska veta att här hemma knullas det varje kväll klockan nio, antingen du är här eller inte".
'IT trubbel
Bästa IT helpdesk !
Förra året uppgraderade jag från Flickvän 7.0 till Hustru 1.0. Så fort jag hade installerat programmet märkte jag att det började kräva att jag skulle installera Barn 1.1, 1.2 och 1.3. Det tog en massa tid och krävde en massa resurser. Det stod det inget om i programspecifikationen. Dessutom installerade sig Hustru 1.0 i alla andra program och dyker upp så fort jag startar datorn - och övervakar alla mina aktiviteter. Gamla program som Pokerafton 10.3, Fyllefest 3.5 och Söndagsfotboll 5.0 fungerar inte längre. När jag försöker starta dem får jag felmeddelandet: 'Du har utfört en otillåten aktivitet. Stäng genast ner alla program som inte stöds av Hustru 1.0 !' Det är omöjligt att hålla Hustru 1.0 i bakgrunden medan jag försöker köra några av mina favoritprogram. Jag har funderat på att återgå till Flickvän 7.0, men jag kan inte ens avinstallera Hustru 1.0.
Kan ni hjälpa mig ? Tack på förhand!
Svar från Helpdesk :
Bästa datoranvändare.
Problemet du beskriver är mycket vanligt och många klagar över samma sak. Orsaken till problemet är ett grundläggande missförstånd. Hustru 1.0 är inte, som många män tror, ett nytto - och underhållningsprogram, utan ett operativsystem som är designat för att styra allt. Att försöka gå tillbaka till Flickvän 7.0 när Hustru 1.0 är installerat är dömt att misslyckas. Några har försökt med att installera Flickvän 8.0 eller Hustru 2.0, men det har slutat med att de fått fler problem än vad de hade med Hustru 1.0.
Vi rekommenderar att du behåller Hustru 1.0 och försöker göra det bästa av situationen, samt att du eventuellt läser hela kapitel 6 i manualen 'Vanliga programfel'. Datorn kommer att fungera perfekt så länge du tar ansvar för alla systemfel, oavsett vem som har förorsakat dem. Det räcker med att du skriver: / FÖRLÅT, så återvänder styrsystemet till normaltillståndet. Hustru 1.0 är ett storartat program som dock kräver ett visst mått av underhåll. Du kan försöka med att köpa tilläggsprogram för att öka funktionaliteten. Vi rekommenderar Blommor 2.1, Choklad 5.3 eller i extremfall mjukvarupaketet Päls 2000.
Vi avråder å det bestämdaste från att installera Älskarinna i kortkort 3.3 eftersom detta program inte stöds av Hustru 1.0 och kommer att resultera i att Hustru 1.0 avinstallerar sig själv och därmed avlägsnar 50% av systemresurserna. Älskarinna i kortkort 3.3 kräver själv stora systemresurser, som inte finns kvar efter det att Hustru 1.0 har avinstallerat sig själv.
Vänligen
Helpdesk.'
:D :D :D
En blond kvinna kommer farande som ett skott på sin fina sporthoj och blir stoppad av en kvinnlig polis som också råkar vara blond.
"-Kan jag få se körkortet?" säger den kvinnliga polisen.
Blondinen börjar frenetiskt riva igenom hela handväskan, och blir mer och mer stressad.
"-Hur ser det ut, nu igen???" undrar blondinen.
Den kvinnliga polisen svarar: "Det är ju fyrkantigt och så finns det ju en bild på dej!"
Till slut hittar blondinen en spegel som är fyrkantig i väskan, tittar på den och räcker över den till poliskvinnan. Den blonda kvinnliga polisen tittar på spegeln, lämnar sedan tillbaka den och säger:
"-Det är okej, du kan åka, jag visste inte att du också var polis!"
