Its proven Combined Brake System links the rear brake pedal to both the compact dual-piston rear brake calliper and the centre piston of its right-side three-piston front brake calliper to provide a measured balance of front brake control whenever the rear brake is firmly used. An inline delay valve ensures that light operation of the rear brake, such as when trailing through a corner, has little or no effect on front brake operation.
Stronger pressure applied to the rear brake pedal results in just enough front brake engagement to provide a more effective balance of front and rear braking forces for smoothly controlled operation. The remaining five pistons of the two three-piston front brake callipers are controlled in a conventional manner by the hand brake lever and provide reassuringly strong braking control to match the CB1000R’s aggressive sportbike riding capability
jäklar vad rå cb1000ra vita var..men lägger inte ut 7k extra för abs, finns en inne hemma som man ska provköra imorrn (-09), sammt z1000(-08)
Med anledning av Ducatis 10... |
Screenshot I samband med... |
CTEK NXT 5 Nu börjar sol... |
Screenshot I kommande nu... |
