Fantastisk kinesisk översättning
Lajf
Sporthojsnörd
2 Apr 2005
Älvängen
CB1300 & Rickman
SUZUKI GSXR1000
Item Number: 55320075
Market Price: 1800 EUR
Member Price: 1000 EUR
VIP Price: 800 EUR
Order
Product show
The Suzuki GSX- R1000( K3) catalogues
Engine form:Four cold DOHC of blunt waters 16 live the petal to be juxtaposed 4 cylinders
Blunt distance of a path x:73.0 mm x 59.0 mm
Compress to compare 12.0:1
Total row tolerance:988 cc
Tallest horsepower:164ps/10,800rpm (Ram-Air Mode 170ps/10,800rpm)
A form of car:A wing beam of the aluminum metal alloy frame type
Spread to move a 6 fronts of system soon the chain spreads to move
The fuel supplies the 42 mm electronics fuel to spray to note the system
The anteversion Cape( R): 24 ¡ãs
The haulage be apart from( T): 96mm
Hanged the system before: The handstand an ex- fork with hydraulic-pneumatic tube of 43 mm, the whole function adjusts to compare
Hang the system behind: The single tube connects the pole type hydraulic-pneumatic avoid the earthquake, the whole function adjusts to compare
Tire( front):120/70 - 17
Tire( empress):190/50 - 17
The ex- ³¸ moves the system:2 The x 300 mm „x car disc goes together with 4 pistons to to card pliers
The empress moves the system:The single disc of 220 mms goes together with a pair of pistons card plierseses
The long x wide x high:2045 x 712 x 1135mm
The stalk be apart from:1410mm
Lowest leave the ground to be apart from the 130 mms
Is high:830mm
The stem is heavy:168kg
A capacity of oil:18L
Custom Bike Show den 6e juni.
Stor invigning på Sulas MC
Nyheter från Wunderlich
Harley-Davidson lanserar RIDE
KTM uppdaterar sin elhoj
