Aprilia RS500
Two stroke man
12 Apr 2005
Där jag tar av mig hatten
Har tappat räkningen
Eller varför inte en RS611 på 140hk?
http://cgi.ebay.co.uk/YAMAHA-BANSHE...itu=UCC&otn=5&ps=63&clkid=6553232249441379333
Men någon gatmotor är det nog inte riktigt om man tolkar Stan Stephens svar på frågorna.
Q: Hi Mr.Stephens. From my conversations with the guys at Trinity, I am led to believe that the 611cc configuration is a DRAG RACE only motor. Furthermore, I also understand that this kit produces a lot of vibration in the mid to hi RPM range and would be more than a handful as a road going motor...to say the least. Having said that, and with all due respect to yourself as a noted 2T engineer, I am interested to hear your views on the above to clarify once and for all the true street worthiness of these big displacement RZ,RD,Banshee motors, in particular the 611cc kit. Many thanks in advance for your reply. Sincerely, Slash. 17-Jan-11
A: You would have to be a brave man to use one on the road!
Q: Stan How suitable is this engine for a road going RD350 and what would the service intervals be eg pisons, rings etc etc Thanks Dave Burr 17-Jan-11
A: The engine is a race engine and is intended for competition use. If you want to put it in a road bike that is entirely up to you! I have a customer who said he wanted a 535cc engine for track days and then complained it was to powerful for the road! But he is a loony!
Niklasinorr
Mr Kvalitet enligt Ståhlis
24 May 2003
Lulstan
KTM EXC 300 TPI samt allt annat med två hjul som jag hittar...
Jo, men hör hur lite den varvar innan han/hon växlar. Och sedan hur den varvar på typ trean fyran. Låter ju som om den inte varvar ur alls på ettan trotts att han drar en stund :confused:
Han med gixxern varvar heller inte ur, jag tror att det är ganska vanligt med kortväxling på ettan, jag brukar också göra det.
R2
På två hjul sen -89
skvde
ett bygge, + en 954 + YZF750R -95 som R7 stylats men också skrotats + Aprilia RS250, + RGV 250 + två RD350 + en kinamoto med egendesignade kåpor, en Stomp MiniGP och en Anaconda mingp-motard och en egenbyggd GP70racer.
Nån som har info på att bygga samma på RGV ram?
Vad jag fattat så passar motorn inom huvudramen på en RS, och så byter man de undera ramrören, eller?
Borde vara samma på en RGV?
Rolle Rotax
8 Dec 2004
Sthlm
ESW Rotax 250/Tz 250
Eller en sån här?
http://www.youtube.com/watch?v=etv7R-uw2Qc&feature=related
Fast två kommentarer på denna,
1. Han som drog avgassystemet måste varig hög.
2. Vad är det för handrörelse han gör när han gasar?
PÅ kommentar 1 måste det vara den som skrev inlägget som är hög och inte inser potentialen och genidraget!
De 2 (eller första någon får rätta till) Tz750orna hada alla 4 piporna under motorn i magen. Nackdelen var dels att piporna inte kunde göras tillräckligt bra pga platsbrist och trots detta så tar piporna i när hojen svänger.
3e året fick cylinder 4 pipa som vänder upp, går bredvid cylindern och sedan byter sida genom att gå 'bakom' alla förgasarna.
NU var det bara 3 rör som fr slåss om platsen under motorn, 2 på var sida och en nedanför i mitten. Perfekt triangel och tar inte i :tummenupp
R2
På två hjul sen -89
skvde
Provkörningsduell, Ducati Hypermotard 698 Mono mot Husqvarna 701 SM!
Just nu är Allt om MC på et...
Course 3-i-1 Paketpris – Förarens val
I den spännande världen av ...
Eldrivna Oruga Unitrack
Distinguished Gentlemans Ride 2024 körs 19 maj
Dags för 2024 års Start2Ride
