Gruppköp - Bluetooth Stereoljudmottagare/sändare
Mr K
I win, you loose!
Hemmestorps Eke
GSXR750-07 & GSXR600-07
Men denna lilla apparat kan man streama (skicka) stereoljud med FULL kvalitet från sin dator, mobil eller annan apparat med bluetooth A2DP till sin stereo eller annan apparat som kan spela upp ljud. Man kan oxå streama (skicka) på motsatt håll. Jag har velat ha en sådan här länge mellan min dator och stereo länge för att slippa en ljudkabel när man ska spela musik men de har varit för dyra. På Kjell & Co har de en som kostar 699kr med samma funktioner.
http://www.kjell.com/?item=91492&path=
Nu har jag hittat en billigare och vill se om andra är intresserade.
* Motorola Bluetooth Home Stereo Adapter DC800
* 100%new Motorola Wall charger AC adapter (EU plug)
* 100%new RCA Audio cable x1, 3.5mm to RCA cable x1
* Ships in bulk packaging (Not in retail package)
* Only whats listed above will be included nothing else, they are samples of repertory, not personal used device.
Enjoy your favorite tunes upstairs and down (up to 30 feet away from your stereo) without making a sound or missing a call. With the Motorola Bluetooth Home Stereo Adapter, you'll be wirelessly listening to your favorite tunes through your headset in no time.
Dimensions: 130mm x 150mm x 70mm
Weight : 3.5 oz
-Supports Bluetooth Streaming music profile (A2DP)
-Audio input and audio output capabilities
-Designed with advanced Bluetooth Class 1 technology which provides a wire-free range of up to 100m (300 ft.) when used with other Class 1 devices
The DC800 Home Stereo Adapter is a Class 1 Bluetooth device. This gadget enriches considerably the functionality of your home stereo system, MP3 player and TV, as well as of another compatible devices, and allows you to enjoy your music like never before. It operates bi-directionally, this means that it helps to stream music using A2DP profile from a handheld or mobile phone through your stereo system. And vice versa, from a stereo system to a Bluetooth2.0 headset.
It looks nice with its silver housing and it is quite lightweight. On its rear it has five jacks – a 2.5 mm jack for a power adapter, right and left channel RCA type connectors for input and output. On the front panel you will find a smaller switch button and a bigger M-button with indicator light needed for initiation of pairing with Bluetooth-enabled devices. The M blinks with a slow pulse while playing music, and flashes quickly in stand-by mode. The DC800 can be placed horizontally or vertically, just as you wish.
The pairing memory of the Motorola DC800 is eight devices. You can add more and more devices, but the oldest ones will be deleted from Adapter's memory. Once paired with a Bluetooth device, the DC800 will connect automatically to this device when it is in range and turned on. The great drawback is that the pairing demands for key entering, so your device has to include a keyboard in order you could enter a passkey. Of course, there is a search function, and the DC800 should find your device itself. The manual says: “Press and hold the Pairing button on the stereo adapter until the indicator light remains solidly lit (about 5 seconds). The stereo adapter searches for Bluetooth devices. When the stereo adapter finds the headphone, the indicator light rapidly flashes indicating that pairing is successful. Once the connection is established, the indicator light changes to a slower, pulsing light.” Though, only sporadic information about someone's success in such pairing is available. In fact, not all the devices can be paired. Only Bluetooth V1.2 and V2.0 deivce could be accepted!
By the way, one more annoyance is the absence of controls on the DC800 itself. Sometimes you need to run to another room and pause the music or change tracks. Using a wireless headset is the best option in this case. The Motorola HT820 is supposed to be a perfect match for the DC800, on condition that you like the headset itself with its pros and cons. Together they work flawlessly. You can use another headset supporting A2DP profile as well.
One more thing is that some users regret there is no rechargeable battery, so they can't take the Adapter out of home (they would like the possibility to take it to the walk, to gym, garden, and to other places in spite of its rather big size).
DC800 could be connected with each other! That means if you buy 2 or 4 or 6 pcs DC800, the signal of Bluetooth could be doulbe or more range!!!!!
Two DC800 adapters can be transfered over 150 feet, there is still clear bluetooth audio!
Priset blir 225kr/st (Det KAN tilkomma moms & tull men till 98% av mina köp utanför EU har jag SLUPPIT detta) om vi beställer minst 5st. Hämtpris hos Mr K. Kan skicka inom sverige mot tillägg av postens avgifter.
Funkar perfekt med en IPhone.
Beställer när vi blir 5st eller fler.
Beställningslista:
1. Mr K - Betalat
2. Pontus - Betala 225,02kr
3. Talpai - Betala 225,03kr
4.
5.
6.
7.
osv
Betala in EXAKT vad jag skrivit annars vet jag inte vem som betalat.
SEB
Clearing 5678
Konto 2921022
Man kan betala Mr K med jämna pengar oxå.
Skall nog kunna ha råd med en vettig pryl :tummenupp
Intresselista:
1. Mr K
2. Alexander
3. Slipsten
4.
5.
6.
7.
osv..
Behöver man någon speciell funktion eller utgång på stereon för att det ska fungera. Om inte så vill jag ha en!
Intresselista:
1. Mr K
2. Alexander
3. Slipsten
4. Gsxr junior
5.
6.
7.
osv..
Beställningslista:
1. Mr K - Betalat
2. Alexander - Betalat
3. Slipsten - Betala 239,03kr
4. Gsxr junior - Betala 239,04kr
5. DevilRider - Betala 239,05kr
6.
7.
osv
Beställer 21/8. Pengarna ska vara på mitt konto senast 21/8 10.00
Man kan vara med sålänge man hinner betala i tid.
SEB
Clearing 5678
Konto 2921022
tips från läktaren (nördvarning)
kolla bara upp vad BT modulen sänder på för frekvens. Vill det sig illa kan BT slå ut ett eventuell WLAN om de ligger och sänder på samma frekvens... OM man nu skulle ha ett WLAN i samma rum dvs...
Har upplevt vissa problem med ett par BT högtalare och WLAN hemma men allt som oftast så kan man skifta vilken frekvens som WLAN:et alt BT-modulen ska sända på.
otorola DC800 Bluetooth Home Stereo Adapter, Model: 89015J
The portable Motorola DC800 streams content to the Motorola HT820 from the stereo and Bluetooth wireless-enabled mobile phones, PCs or other devices. For group listening, music can be played through the stereo speakers. By streaming music to your the Bluetooth Stereo Headphones, the Bluetooth Home Stereo Adapter turns audio devices such as home stereos and MP3 players into wireless music systems. Just plug the DC800 into your home stereo or MP3 player with an included RCA cable or 3.5mm cable and you are ready to go. You can even hook up to your RCA capable TV.
Specifications: Manufacturer: Motorola, Inc. Interfaces/Ports: Not Applicable. Manufacturer Part Number: 89015J. Frequency Band/Bandwidth: 2.4 GHz ISM Band. Product Name: DC800 Bluetooth Home Stereo Adapter. Product Type: Wireless Converter. Wireless Technology: Bluetooth. Certifications & Standards: Bluetooth.
Detta problemet har jag aldrig fått men jag ser problematiken. Borde lösa sig lätt isåfall att man ändrar kanal (frekvens) på WLANet.
Alltså "slå ut" WLAN var väl å ta i :rolleyes: men man kan uppleva en försämring av signalstyrkan för WLAN men som sagt, det är bara byta frekvens. Kör för övrigt ett liknande system (hemmabygge dock) ihop med WLAN och funkar kalas så det är helt klart värt att slippa lite sladdar. Lycka till med köpet!
Överföring gjord, du bör ha pengarna på måndag :tummenupp
Beställningslista:
1. Mr K - Betalat
6.
7.
osv
SEB
Clearing 5678
Konto 2921022
Taget ur första inlägget: Designed with advanced Bluetooth Class 1 technology which provides a wire-free range of up to 100m (300 ft.) when used with other Class 1 devices
Det är ju optimala förhållanden. Jag skulle tippa på en faktisk räckvidd på 50m innomhus med lite saker ivägen.
Vilket också förutsätter att din andra enhet är en klass 1 enhet, vanlig klass 2 enheter har enbart en räckvidd på 10 meter i optimala förhållanden
Aaahh! Jag läste inte. Alldeles för mkt text för mig... :tungan
Jag fattar ingenting :confused:
Men det blir nog bra. Har inte mer än 10 meter ändå...
Beställningslista:
1. Mr K - Betalat
3. Slipsten - Betalat
5. DevilRider - Betalat
6.
7.
osv
SEB
Clearing 5678
Konto 2921022
Beställningslista:
1. Mr K - Betalat
4. Gsxr junior - Betalat
6.
7.
osv
SEB
Clearing 5678
Konto 2921022
A ride for our child, Tyra
Mälaren Runt #40 – 16 augusti
Specialbyggd Yamaha XSR900 GP
Screenshot Den 16–17 aug...
En vecka kvar!
