Bilder på nya KTM 990 Duke
Wiseguy
Medlem nr.8 sen starten
Introduction to the KTM 990 Duke
The engine weighs 58kg, approximately 20% lighter than the competition
V-Twin, 999cc displacement
Short stroke, 75° Vee
Electronic fuel injection
LC8 engine is vertically split at different levels for a space saving arrangement of the crankshaft and the two shafts of the six-speed gearbox
A space saving multifunction shaft rotates in the Vee between the two cylinders, supporting the two counterweights, drives the water pump and the centrifuge of the engine case vent, also serving as an idler gear for the starter and two timing chains
A near linear torque curve
Dry sump lubrication with a 3-litre oil tank under the radiator
122hp @ 9,000rpm
99Nm @ 7,000rpm
Cylinder heads and gearbox ratios are different from the 950 Adventure
Frame is made of chr0-moly tube and weighs under 9kg
Dry weight of 179kg with fuel and oil weight is 195kg wet
Weight distribution is 51% front / 49% rear
Low mounting of the engine and positioning of the battery lead to a very low centre of gravity
Fuel tank holds 15 litres
White Power shock absorber linked directly to swingarm, fully adjustable for both low and high speed compression damping, rebound damping and preload is also adjustable
Forks are 48mm White Power upside-down with 'multi adjuster'
Seat height is 850mm
Brembo radial master cylinder with 320mm discs and 4-piston Brembo calipers
240mm disc at the rear with Brembo single-piston caliper
3.5" front rim and 5.5" rear rim
Tyres are 120/70-17 up front and 180/55-17 at the rear
KTM 990 Duke - Specifications
Engine - V-Twin, 4-stroke, 75° Vee, DOHC
Displacement - 999.8cc
Bore x Stroke - 101 x 62.4mm
Claimed Power - 122hp @ 9,000rpm
Claimed Torque - 99Nm @ 7,000rpm
Starting - Electric
Transmission - 6-speed, dog clutch engagement
Induction - Electronic fuel injection
Cooling - Liquid cooled
Clutch - wet multi-plate, hydraulic
Frame - Chro-Moly tubular space frame, powder coated
Subframe - Aluminium
Front Suspension - 48mm WP USD adjustable, 135mm travel
Rear Suspension - WP shock, fully adjustable, 160mm travel
Front Brakes - 320mm discs, Brembo 4-piston calipers
Rear Brake - 240mm disc, Brembo single-piston caliper
Rims - 3.5" x 17 (F), 5.5" x 17 (R)
Tyres - 120/70-17 (F), 180/55-17 (R)
Steering head angle - 66.5°
Trail - 103mm
Wheelbase - 1,438mm
Ground Clearance - 165mm
Seat Height - 855mm
Fuel Capacity - 15 litres
Dry Weight - 179kg
Wet Weight - 195kg
Herrejävlar... jag gillar den skarpt, undrar var den kommer att kosta och vad försäkringen landar på,
mums :p
AAAAAH Skit snygg.
Har ju varit ute på reklam annonser länge men har aldrig sett den på riktigt, är den släppt först nu eller har den funnits ett tag?
Det tråkiga blir nog att den blir dyr i försäkring, då den har 122 hk. Annars är den klart läcker.
toca1 skrev:
kommer å tänka på Kawa Z1000 när jag ser den ???
Jo kanske det men kolla på ALLA sporthojjar. Vem kom först? Hönan eller ägget? Alla ser ju likadana ut så... Får nån en försäljningssucce så hakar såklart alla andra efter. tyvärr. Tråkigt för oss åkare. Det värsta är att vill man sticka ut (RSV Mille osv...) så kostar det! :zpy
jag gillar hojjen... skulle verkligen kunna tänka mig en.
Har redan börjat drömma om moddning :rolleyes:
    103.9 KB · Visningar: 380
Ducati DesertX 2026
KTM firar 100 år av 6DAYS
